Probably a boring thread but I couldn’t find the “What did you do to your XK today?” Thread.
Took the afternoon off to clean and coat my wheels.
Nothing professional or fancy. Just a cleaning and cheap ceramic coat. (MR chemical HydroSpin)
The brake dust on these ceramic pads, especially in the front, is atrocious. New-ish so not replacing them anytime soon.
The rims on the inside need a pro polishing which is why I’m not doing a deep clean and expensive ceramic coat. Very bumped and pitted.
While the wheels are off, gonna use degreaser on the Alcon brakes. They are filthy.
Some before/after pics.
Front passenger before:
Rear passenger before:
Both after cleaning:
Front Alcon before (rear looks same lol):
Alcons after:
I’ll add post ceramic if they look different when I’m done. Having a smoke and back break…can’t stand up straight at the moment.
Next home project will be those horrific hubs.
Researching chemical/wire brush to remove the rust and some high temp rust prevention engine paint.
Gave my back a day of rest and doing the driver’s side now.
Things I observed:
If you don’t break the lugs before you jack/stand the car, you won’t be able to stand up straight for a few days. (Duh moment)
That fabric our wheel liners are made of are really durable. Mine look like new at 17y old and 83k miles,
They should make a car out of this stuff. Or a space shuttle. Yeesh.
Quick shop vac and they are cleaner than the rest of the car.
Get a proper wheel brush. The crap one I got with some detailing kit on Amazon won’t touch the many crevices.
Degreaser is a miracle worker.
Time will tell. If it doesn’t work out, I’m ok removing the ceramic coating and starting over with a better product.
That is kind of why I went mid level to start.
Is that weird?
When I was in there with the work lights, I could see sticks and pieces of leaves all over.
Also caught a few half tightened screws.
I know it will get dirty again, especially here in the Fall, but at least I have a good clean starting point.
