Sponsored by: DashLynx
Interior cleaning question
Old 06-17-2018, 02:13 PM
xialiulaoren's Avatar
Default Interior cleaning question
Hi all, recently my buttons in XK get very sticky and feels terrible to touch.... have searched many threads online but still don't know what kind of product is the best solution for this issue..
these three buttons are the worst in the interior.
just wanna if I can use baby wipe to clean it? Or just a microfiber towel with some water? Cause I am afraid those kind of chemical product will ruin the paint of the buttons... so I prefer just to use something as common as possible
thanks in advance
Old 06-17-2018, 02:31 PM
Ranchero50's Avatar
Basic dish soap does wonders as do some oils
Old 06-17-2018, 02:54 PM
Stuart S's Avatar
Received 6,141 Likes on 3,384 Posts
Trying to clean the buttons might remove the graphics, depending on the ingredients in that cleaning product. I'd try a drop of hand lotion on my fingertip, rub it gently on a small part of the sticky surface and see if it helps.
I have a soft plastic case LED flashlight that got sticky over time. Hand lotion removed the stickiness and made it like new.
Old 06-17-2018, 04:18 PM
Thanks for sharing. So you mean hand lotion NOT hand sanitizer right?
will microfiber with some water work?
Old 06-17-2018, 04:27 PM
Ranchero50's Avatar
I try to avoid anything that is defatting like hand cleaners or alcohol based products. Plastics need oils to survive.
Old 06-17-2018, 04:51 PM
ok I see. So actually those shiny buttons are not metal just plastic? There is a 3M product here that is recommended for plastic cleaning. If they are plastic I guess this one will work.
Old 06-17-2018, 04:58 PM
Ranchero50's Avatar
It's acid based, acids are defatters (remove oils). I'd avoid it.
Honestly I'd start with water and a microfiber towel. Remember, whatever is on there was on your hands at one time. Women love lotions and they leave a gummy residue as well.
Old 06-17-2018, 07:28 PM
mosesbotbol's Avatar
Received 1,197 Likes on 931 Posts
Light dishwashing soap solution on a wrung towel is pretty mild first attempt.
3M stuff interesting. I have their leather cleaner and it takes out jean dye in a blink.
Old 06-17-2018, 07:30 PM
Malt's Avatar
Cool
Looked at a XK at my local dealer before buying the one I own. It was off lease from FL and all the plastic buttons were sticky. I talked to the service manager about it, a woman, and she said it was due to a driver using hand lotion and not letting it soak in before driving the car. No way to correct it.
I'd try the water and microfiber as Ranchero suggested and then work up from there if that doesn't work. Those plastic and rubber button tops are easy to mess up. But I hate sticky - so did not get the car from the dealer.
Old 06-17-2018, 08:45 PM
Stuart S's Avatar
Originally Posted by xialiulaoren
... So you mean hand lotion NOT hand sanitizer right? ...
That's what I said:
"I'd try a drop of hand lotion on my fingertip, rub it gently on a small part of the sticky surface and see if it helps."
Old 06-17-2018, 09:18 PM
Stuart S's Avatar
Default Don't Risk Damaging the Graphics
I went to Amazon and read the label on that 3M product. It does not state that it is safe to use on printed plastic.
"Description
Adhesives - 3M™ Citrus Base Cleaner - A liquid cleaner/degreaser that can be used to dissolve and remove dirt, grease, tar, and many non-curing type adhesives. It can also be used to degrease substrates for adhesive bonding in place of many chlorinated or petroleum-based solvents. Net weight is 18.5 oz each."
Citrus based products like this one from 3M contain d-Limonene, which is a cleaner and degreaser. I would not use it to clean the sticky buttons because it might be too strong and damage the graphics.
The concrete floor of our 100,000 sq. ft. warehouse was cleaned by a contractor that used a d-Limonene product to completely remove years of accumulated forklift tire rubber and other ground-in dirt. The result far exceeded my expectations - the concrete floor looked like new. A side benefit was that the warehouse smelled like an orange juice factory for weeks.
d-Limonene is also used in many waterless hand cleaners.
I repeat my suggestion to try a drop of hand lotion. Not the thick, goopy stuff, but a thin viscosity that can thin out the stickiness, be wiped off, and another light coat applied that is absorbed into the plastic. That worked for me to restore my LED flashlight housing.
Old 06-18-2018, 07:45 AM
TXGladiator's Avatar
Smile
This is a very common issue.
Google 'sticky Jaguar buttons" to learn about ways like this to clean them:
The coating that was originally intended to create the soft touch feel is deteriorating with age, giving it a sticky feel. You need to remove that layer. Dealers do this all the time using Noxema makeup remover pads - lots of rubbing!
Old 06-18-2018, 06:22 PM
Queen and Country's Avatar
Received 2,380 Likes on 1,607 Posts
You too will swear by this stuff.
And it should solve the sticky problem the right way, not by removing the coating but sealing it.
Its new technology.
Amazon Amazon
Old 06-18-2018, 06:26 PM
Its a miracle formulation by a Phd.
They have similar but more concentrated formulation for tires, and you will never go back to silicone for tires.
Amazon Amazon
Ceckman (06-18-2018)
Old 06-24-2018, 07:27 PM
CatScratchFever's Avatar
Hi, what is the 3M leather cleaner you refer to that removes denim staining? Thanks Allan
Old 06-25-2018, 09:18 AM
FYI
Prevent denim stain- use Ink Stop by Leather Masters. Its the only leather protection and conditioning ever needed- according to the leather institute in UK.
The following 2 users liked this post by Queen and Country:
CatScratchFever (06-25-2018), pwpacp (06-25-2018)
Old 06-25-2018, 10:28 AM
https://www.3m.com/3M/en_US/company-...3241098&rt=rud
The following 3 users liked this post by mosesbotbol:
CatScratchFever (06-25-2018), pwpacp (06-25-2018), Queen and Country (06-25-2018)
Rossy
02-17-2015 08:06 PM
jagosaurus
03-20-2011 03:39 PM
PaulB
03-11-2011 11:41 AM
GrahamS
Interior
12-30-2010 07:49 AM
Oubadah
Interior
08-18-2010 06:36 AM
Quick Reply: Interior cleaning question
