XKR Engine Air Filters Change Issue RESOLVED
Old Dec 21, 2013 | 05:12 PM
richzak's Avatar
Originally Posted by Brutal
IT IS your damn issue, they not only need to be the same brand. but jaguar found out that even the same matching date code!!!!. just the differance in filter media construction from one batch to another can cause air to fuel ratio imbalances and check engine lights. We used to deal with this all the time till jaguar now only supplied them in a "paired matched set" tell your parts guy this is the 21st century and no longer as simple as he wants to think. Order a set or go pick them up at the dealer, its not hogwash
Thanks for this info.........
I have a 2009 XKR Portfolio Edition Convertible with 14,800 miles. How often does the engine air filters need replacement? I am not sure about the mileage interval. I am not having any reported problems. I just ran across this thread, so any advice would be helpful especially from a Certifed Jaguar Tech. Thanks in advance for your time and effort to respond.
Old Mar 27, 2014 | 06:29 PM
GWS's Avatar
GWS
Default Changed the MAF Sensor Drivers Side (B)
2007 XKR. After living with the occasional amber check engine light for quite a while, I finally got the time to replace it. What a job! Trying to get everything to line up on re-assembly was the worst of it. But now that it is changed I took it out on the road and held 70 mph for 30 minutes, then did some passing to 90+ mph and back to 70 for another 30 minutes. No amber check engine light so far. Ran my first SCCA solo event in the Jag. What a rush. It has been 42 years since I went around the pylons (then in my 1959 Bug Eye Sprite). Thanks to everyone who supplied assistance and support. Next job is to change the spark plugs. Almost 100,000 miles on the odometer.
Old Mar 30, 2019 | 09:44 AM
FEButler's Avatar
Default XKR Air Filter Change
This is great information on the XKR air filters. Why not simply install a high quality performance air intake tube with a K&N filter as sold by Mina Gallery? I believe they are more noisy at higher rpms.
Old Mar 30, 2019 | 12:31 PM
Stuart S's Avatar
Here's why not: https://www.jaguarforums.com/forum/x...intake-213341/
You're a newbie, so welcome to the Forum. You should create a signature (see mine, as an example) that includes your location and year of your XKR and any other info you'd like to share, to make it easier for members to reply to your questions. Also, many questions have already been asked and answered, so learn to use the Advanced Search function. There's no need to reinvent the wheel. It took me less than 30 seconds to find the above link (because I remembered that I posted a reply). There are several more K&N threads, so if you're interested it's a good time to learn to use Advanced Search. Be sure to select the specific Forum (X150) to narrow the search results.
Old Mar 30, 2019 | 06:15 PM
FEButler's Avatar
Default Air filters for 2007 XKR
Thanks so much for the info. I'm convinced its best to stay with the stock intake system, and probably OEM filters
Old Apr 2, 2019 | 12:37 AM
AlexJag's Avatar
Sponsor
Stock setup is restrictive up to 1.5psi negative preasure at WOT so definitely room for improvement. Member Jahummer is running custom intake setup with two dual cone filters , do not believe he has any issues with Maf maybe he can correct me.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Apr 2, 2019 | 10:54 AM
Stuart S's Avatar
Unless you track your X150, what's the point in modifying the air intake?
Old Apr 2, 2019 | 11:02 AM
  #28
Cee Jay's Avatar
Track it with each second saved vastly important.
Old Apr 2, 2019 | 11:08 AM
neilr's Avatar
None that I can see, even if you track a standard one. Jaguar will have sized the air intake to exceed the requirements of the engine, even allowing for quite some clogging of the air filters. If it was so easy to make improvements to a high-tech product, those engineers must be rubbish and how on earth did they manage to build such a good car in the first place. Also, we might tweak one thing and mess up the balanced compromises that the people with all the info selected. I'm not keen on trial and error "engineering".
Old Apr 2, 2019 | 02:15 PM
  #30
AlexJag's Avatar
Sponsor
To each their own I guess .if I wanted the car stock I would keep it as such but I love modifying and improving and so do many others. I'm pushing nearly a hundred horsepower more so stock airbox is definitely in the way.
__________________
Old Sep 24, 2020 | 11:55 AM
  #31
Sportjag's Avatar
Default Filter U
Originally Posted by GWS
On the XKR we have two filters, one on each side of the car and they are in front of the wheels behind the inner fender skirt. The instructions would have you remove the front bottom shield and release the front of the skirt (8-10 screws) and bend it back over the brake rotor. I found the second time that removing the bottom shield was not necessary so it saved a little time. The air boxes are held closed by two screws rather than clips. If you do not clean all of the interior of the box very well, when you put the screws back in it will strip the threads trying to overcome the dirt. The covers fit very tightly and I found spray silicon lubricant to help when trying to re-assemble. Check the gap and don't tighten the screws if there is more than a fingernails width after assembly. Worst case, small rubber hammer to get the last mm of gap closed.
thanks for all the filter information. I just bought a 2010 XK and sent it to the shop for filters and oil change. The information has inspired me to take on the filters myself. Thanks
Old Sep 26, 2020 | 12:34 AM
  #32
pk4144's Avatar
And remember there's no fuel filter change for our cars, so air filters are it.
Old Sep 26, 2020 | 05:41 PM
  #33
guy's Avatar
guy
Apoligies for the deviation but I did read you statement with interest, @pk4144 ... so I had to check the differences. Thats an interesting situation in the MY10. I wonder what was the motivation for that.
I see the fuel pump does incorporate a filter... can that not be changed? For example, I did replace the power steering reservoir in order to have the effect of changing the filter.
File Type: pdf
File Type: pdf
Old Sep 26, 2020 | 05:43 PM
  #34
pk4144's Avatar
Don't know. Personally I find it odd not to have a fuel filter, but so far, so good...
jasonbcoutant
Oct 20, 2017 11:27 AM
WaterDragon
Sep 30, 2015 02:00 PM
Mendo XK
Apr 1, 2015 11:59 AM
trosty
Oct 17, 2013 04:46 PM
GhostriderXKR08
Apr 3, 2011 04:57 AM
