XKR Lights
Old Oct 9, 2012 | 12:00 PM
shanealbrandt's Avatar
Default XKR Lights
Hi,
I have a 2007 XKR and I like the look of the new 2012 (even the 2009) XKR lights because they are LED. Are these interchangeable? I called the dealer and they said no, but then I see people post about changing them out all the time?
Thoughts??
Old Oct 9, 2012 | 02:12 PM
Shane,
I've moved this from XK8/XKR 1996-2006 section. Members here are more likely to know if this swap is feasible or if there is an alternative solution.
Old Oct 9, 2012 | 04:44 PM
Rahtok's Avatar
There is a swap, but it's not cheap. There are a couple of different people that did some harness conversions for the wiring bit. Do a search in this sub forum for it.
Old Oct 10, 2012 | 05:23 AM
johnnnnnnyy's Avatar
Mine have been changed and work perfectly
Old Oct 10, 2012 | 05:26 AM
I found the post here:
https://www.jaguarforums.com/forum/x...ght-kit-72462/
Old Oct 10, 2012 | 10:22 AM
Default XKR Lights
Johnny,
Which kit did you purchase? I see a few different kits mentioned in the thread - but not which one is best - and where to get them?
Old Oct 10, 2012 | 10:42 AM
GordoCatCar's Avatar
Remember there are two (2) options here. First is to replace the complete front or rear light assembly, which includes the buckets and the outside glass or plastic lens covers. I think the OP is discussing this option.
Or you can buy LED bulb conversions kits. These are available all over the web, from dozens of suppliers.
Old Oct 10, 2012 | 11:01 AM
LED Bulb conversion kits? So that would mean literately opening up my current tail light and changing out the bulb for a LED light?
Old Oct 10, 2012 | 11:39 AM
It's not a bulb for bulb swap. You need to replace the whole light unit (Get newer 2012 ones), there always plenty of these lights on UK Ebay, not sure in the US?
Read the tread link I posted above.
Old Oct 10, 2012 | 12:19 PM
GhostriderXKR08's Avatar
You can also try George's write up on Page 3 (PDF Form). My mechanic used his writeup and was sucessful.
https://www.jaguarforums.com/forum/x...updates-36907/
FrickenJag
Jun 16, 2025 02:15 PM
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
Skeeter
Sep 17, 2015 08:15 PM
colorancher
Sep 3, 2015 02:29 PM
