Gear selector plate removal
Old Aug 27, 2012 | 08:01 AM
azeteg's Avatar
Default Gear selector plate removal
Since my gear selector plate is in a rather bad condition, with cracks and scuffs, I would love to either replace it (if I can find a new one), or to refinish it myself.
I just attempted to get the darn thing off, but no success. JTIS also doesn't have a procedure for it. Any ideas?
Old Aug 27, 2012 | 08:19 AM
graham11's Avatar
Default gater remove
click on the how to videos,video number 21 by rev sam,i think this is what you are looking for.
steveinfrance's Avatar
Arm yourself with two credit cards and watch the Rev Sam's video which is post 21 + 22
here
https://www.jaguarforums.com/forum/x...-videos-77768/
Graham, SNAP, simultaneous posting!
Old Aug 27, 2012 | 08:23 AM
Others have read this as meaning it's the J gate surround you want to remove. Your arrow points to the J gate itself........?
Old Aug 27, 2012 | 08:41 AM
Stamford's Avatar
One of Rev. Sam's Youtube videos show how he removed his. It's a little tricky if you haven't done it before:
Old Aug 27, 2012 | 09:01 AM
azeteg's Avatar
Right - the top of the J gate has a plastic cover, with the numbers anf letters on it. This is what I want to remove!
I already had my surround out, mine is of solid aluminum, which was clear coated. I sanded the scratched coating off and gave it a brushed aluminum look.
Old Aug 27, 2012 | 09:27 AM
The J Gate is fixed with three screws:
Easier to see in a diagram:
There seems to be no way to then split this plastic section down any further.
I think it would be very difficult to refinish and renumber the gear positions. A good used part has to be a better option?
Attached Thumbnails Gear selector plate removal-j-gate-selector.jpg   Gear selector plate removal-2005-j-gate.jpg
Old Aug 27, 2012 | 09:40 AM
azeteg's Avatar
Actually, the top plastic plate seem to be removable, by first undoing the large torx bolt, then lifting the plastic surround top up - but mine only comes loose on certain sides, others are fixed - probably some plastic hooks in place, but I cannot figure out how they work.
I would love to find a used part, but I have so far been unsuccessful with this.
Old Aug 27, 2012 | 09:51 AM
azeteg's Avatar
There is an old post over in the XJ forum where this has been discussed. The left item in the image depicts what I'm after (but in the 6sp version).
Old Aug 27, 2012 | 11:00 AM
......... The left item in the image depicts what I'm after (but in the 6sp version).
Check your forum PM's
Old Jun 21, 2014 | 01:37 PM
samwhigham's Avatar
Hi guys
I know this is an old thread - but did you ever manage to do it (separate the plastic with the letters on from the j gate module) i'm trying to do the exact same thing on an XKR. I think i have a part ordered.
Old Jun 23, 2014 | 01:01 PM
jsulliva's Avatar
Yes, I have done so. This from memory as it was awhile ago. Flip it over and remove the micro-switch (with roller) at the top (top being the end closest to the dash/radio/AC Controls) by gently squeezing the tab in the plastic rivet holding the mounting bracket and slipping the rivet out. You really only need to remove one side. Undo 2 tiny TORX T-6 screws on opposite sides that hold the top plate to the body and one tiny phillips screw. I have T-6 TORX screwdriver from working on an iPhone. Top plate should now lift off. I do not recall if there were any plastic latches or just the screws holding it together.
I did this to replace the lamps that illuminate the j-gate at night. There are 2 small lamps which are soldered to the little circuit board which is laid out in the picture above. I replaced them with some LEDs and it works great. I thought I had a picture on my phone but can't find it so perhaps on the camera at home. I have more LEDs if interested as I had to buy a package of 25 and only needed 2. Hardest part was getting the wire connector back in place around the shifter.
Old Jun 24, 2014 | 04:33 AM
samwhigham's Avatar
Thanks - i think the bulbs are ok, but ill check.
ill give it a go and let you know how it goes, thanks for the advice
Old Aug 19, 2021 | 09:26 AM
Markmbaha1's Avatar
Default Did you get it off
you can see mine is broken. Did you get yours off and how to find a replacement?
ty mark beachmark9@gmail.com
bamforp
Aug 14, 2024 05:36 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
user 652867429824
Oct 28, 2015 10:18 AM
hen555
Sep 7, 2015 11:13 PM
