“Black Box, Flight Recorder” in the AJ27 ECM
Old Jan 29, 2020 | 09:54 PM
crbass's Avatar
Default “Black Box, Flight Recorder” in the AJ27 ECM
Learned something new tonight. My ECM is keeping tabs on me in the event I crash into a barrier at 155 mph and trip the inertia switch. Or do anything and trip the inertia switch. From the Service Training Course 881:“Black Box, Flight Recorder” / Inertia Switch Monitor
The ECM records 10 seconds of throttle operational data in a “rolling’ memory in the volatile battery backed RAM.
The data is continuously updated and stored during engine operation. In the event of the inertia switch being
tripped, an ignition switched ground is applied to ECM pin EM82-12. The ECM copies the last 10 seconds of recorded
throttle data into nonvolatile EEPROM and DTC 1582 is flagged. The DTC is cleared using PDU.
Old Jan 30, 2020 | 04:10 AM
STLTHMSTA's Avatar
Big brother is everywhere.
Old Jan 30, 2020 | 06:51 AM
Mad Hatter's Avatar
They can't recover that information if you crash it well enough.
Old Jan 30, 2020 | 08:08 AM
dibbit's Avatar
I was wondering how non volatile EEPROMs are after hitting a barrier at 155mph.
Old Jan 30, 2020 | 08:22 AM
Mad Hatter's Avatar
Surprisingly reliable since it has no moving parts.
Old Jan 30, 2020 | 08:45 AM
dibbit's Avatar
The parts will be moving at 155mph before suddenly becoming non-moving.
Old Jan 30, 2020 | 09:00 AM
Mad Hatter's Avatar
bahaha
good point
Old Jan 30, 2020 | 09:04 AM
JagV8's Avatar
Not that suddenly. Big deceleration, sure. (All sorts of parts are going to crumple etc.)
Reading the NV memory quite likely a low priority in that situation, too!
crbass
Feb 14, 2020 11:06 AM
plums
Dec 9, 2012 04:19 AM
jagspeed
Mar 21, 2011 01:59 AM
xtype owner
Mar 19, 2009 11:16 AM
