05/06 Factory Bluetooth - Do You Have ?
Old Jul 30, 2008 | 07:50 PM
o2manyfish's Avatar
Default 05/06 Factory Bluetooth - Do You Have ?
Hey guys,
So I recently got an 06 XK8 with the Alpine Premiun System, w/Navigation, w/Bluetooth.
For the past couple of years I have been using Bluetooth with my Garmin portable system, so I know the bluetooth in the phone is pretty stable.
However, since I have gotten the bluetooth connected in the JAG it's totally reliable.
About 30% of the time when I start the car, the car thinks it has placed a call and the stereo shows the call duration.
About 70% of the time when I answer an incoming car I get dead silence in the car. This occurs whether the car is stopped or moving at speed.
About 20% of the time when I answer an incoming car, I get about 40% of the conversation through the car speakers
About 10% (or less) I get acrystal clear connection through the blue tooth system, and I can carry on a conversation with the top down (windows up) at up to 70mph.
Over 3/4 of my outgoing calls are silent. So I have stopped initiating calls from the car unless I am parked.
Does anyone else with this system have any experience they could share. Am I unique ? or is this typical for this system ?
I doubt it is related but the Navigation system is without a satellite connection about 30% of the time. And usually only has a green satellite signal 20% of the time. Most of the time the navigation system is off by at least a couple of blocks.
Dave
Old Aug 1, 2008 | 08:30 AM
stevef's Avatar
Default RE: 05/06 Factory Bluetooth - Do You Have ?
My last car was an 06, when I first got it the dealer replaced the blue tooth module
According to them it was an updated version, of what orig came with the car.
I had no problems with it after that, I was using a Moto V3
I also had a little problem with the nav being off a few blocks but
that was rare.
Old Aug 1, 2008 | 08:53 AM
geowben's Avatar
The bluetooth in my '06 works well. However, with the top down, I can't carry on a conversation with anyone. Too much background noise for them to hear well if I'm going faster than 30 mph or so. I have a Verizon Razor.
Old Aug 1, 2008 | 12:48 PM
o2manyfish's Avatar
Thanks for the responses.
I understand about the windnoise. But I have had two conversations via bluetooth at freeway speeds with the top down without any issues being heard, or hearing the conversation. However, most of the time I hear nothing regardless of the speed I am travelling.
The car is going into the shop for a couple of weeks ( I was hit by a drunk driver) and I will ask about the updated bluetooth module.
Thanks,
Dave
Old Aug 2, 2008 | 01:09 PM
jag_genius's Avatar
had the exact same thing on a customers.. car..05or 06 xk victory edition.. as soon as i got in the car the radio wud give me time duration.. i replaced the phone module and it worked perfectly after that
Old Aug 2, 2008 | 02:01 PM
o2manyfish's Avatar
Jag Genius,
Thanks, Its going into the shop on Monday I will see if I can get them to update the phone module.
Have a good weekend.
Dave
Old Aug 3, 2008 | 07:56 PM
jag_genius's Avatar
i tried updating it.. but still wudn't.. shud need replacing..
Old May 5, 2009 | 02:11 PM
bkrpdx's Avatar
Default How do I know?
I just bought on 06 XKR Conv. It has the Victory Edition package which I thought meant it would come with Blue Tooth. It has a microphone near the rearview mirror. It has a manual for Blue Tooth. But when I follow the instructions to add a phone (push the phone icon, dial ##3#*# or something like that) it just says "No Phone." How do I know if I have Blue Tooth? If I have it, what am I doing wrong?
Thanks.
Old May 5, 2009 | 11:07 PM
hlgeorge's Avatar
The Bluetooth will only work with certain phones! Your phone may not be compatible.
Old May 6, 2009 | 09:12 AM
bkrpdx's Avatar
Default Bluetooth
Lew,
Thanks for the reply. I understand my phone may not be compatible, but I cannot even get to that point. According to the manual, I am supposed to hit the phone icon button, enter the code, and it will say "discovering" or something like that. Only then do I activate my phone and would I find out if the phone is compatible. But when I hit the phone icon button, it says "no phone" and never gets to discovering. The code does nothing Am I doing something wrong? Do I not have Bluetooth?
Thanks again,
Brian.
Old May 6, 2009 | 10:12 AM
SeismicGuy's Avatar
Thanks,
Dave
Dave--it seems like you have had the worst run of bad luck with the car. First was considerable undercarriage damage from hitting a rock and now a drunk driver. How bad was this latest incident?
Doug
Old May 7, 2009 | 01:04 PM
jpamparts's Avatar
Former Sponsor
BKRPDX-
If you'd like to e-mail me the last 6 digits of you're VIN I can run your options and see if you have the bluetooth module installed.
If you give me your phone model I can run that by their compatability list as well.
That goes for anyone else here too..
-David
www.JPAMPorschejaguarparts.com
Old Oct 2, 2009 | 09:08 PM
malcdean's Avatar
Originally Posted by jpamparts
BKRPDX-
-David
I am about to buy this car. Could you run the options and see if i have bluetooth as well as anything else i should know about (XM?).
SAJWA74C04SG21936
Old Oct 6, 2009 | 01:44 PM
jpamparts's Avatar
Former Sponsor
Malc-
This car does not have the factory bluetooth system installed. I don't believe that sat. radio was available as an option until 08.
There doesn't seem to be any unusual options on this car either that wouldn't be obvious. Navigation, cd changer..
-David
Jagzzz
Aug 8, 2021 02:45 PM
Larry-Cleveland
Feb 9, 2019 03:17 PM
Johncy2000
Oct 2, 2015 01:05 AM
42Ajd
Sep 26, 2015 07:04 PM
