1999 XKR Heater Not Working
Hello my 1999 XKR heater won't work.i have changed the heater pump but still no heat, has anyone had this or knows how to fix it?
Many thanks, Gerard.
I had the same issue.
Check your fog lights work - they are on the same fuse as the heater pump. It’s a 5 amp fuse in the engine compartment, left side (looking from in the cabin) - sorry I can’t remember the fuse number but there is another thread on the forums covering this. If it’s blown it may well blow again, then either risk a 7.5 amp fuse (I did temporarily and it’s not been a problem) or try and find the issue.
That's great advice but I'm sure with my car that when I turn the ignition on and the car starts its System Check, I can easily hear the sloshing sound as the pump starts circulating. Unless there are differences between model years. if you don't hear any sloshing sound, then something is wrong.
Richard
Richard
No supercharger on my models.
Richard
Richard
I've read that somewhere, but mine always seems to come on with the ignition. Not cold enough?
Check F15 (10A) in the engine compartment fusebox, and, as per Hunty's suggestion, F3 (5A) in the same fusebox. If it's the latter, then the Active Sounder (behind RHS headlamp under the liner) is probably dead and can be disconnected.
THank you all, I left the car running to warm up to check the heater hoses as Richard suggested and the heater started working, I guess there must have been an airlock. But all good now thank you all!
