1999 XKR Heater Not Working
Old May 17, 2026 | 08:03 AM
Gerard's Avatar
Angry 1999 XKR Heater Not Working
Hello my 1999 XKR heater won't work.i have changed the heater pump but still no heat, has anyone had this or knows how to fix it?
Many thanks, Gerard.
Old May 17, 2026 | 09:23 AM
RichardS's Avatar
Is the heater hose going to the heater matrix and the return hose in the engine bay getting hot?
Richard
Old May 18, 2026 | 09:26 AM
Hunty60408's Avatar
I had the same issue.
Check your fog lights work - they are on the same fuse as the heater pump. It’s a 5 amp fuse in the engine compartment, left side (looking from in the cabin) - sorry I can’t remember the fuse number but there is another thread on the forums covering this. If it’s blown it may well blow again, then either risk a 7.5 amp fuse (I did temporarily and it’s not been a problem) or try and find the issue.
Old May 18, 2026 | 10:23 AM
motorcarman's Avatar
Just 'jump' the heater pump relay and listen of feel the pump.
You can also see if the circuit is drawing current with an ammeter?
Heater pump relay is in the ENGINE COMPARTMENT FUSE BOX RELAYS
File Type: pdf
Old May 18, 2026 | 10:36 AM
RichardS's Avatar
That's great advice but I'm sure with my car that when I turn the ignition on and the car starts its System Check, I can easily hear the sloshing sound as the pump starts circulating. Unless there are differences between model years. if you don't hear any sloshing sound, then something is wrong.
Richard
Old May 19, 2026 | 12:18 AM
JaagXKR's Avatar
The sloshing sound you hear may be the supercharger pump.
Old May 19, 2026 | 02:41 AM
RichardS's Avatar
No supercharger on my models.
Richard
Old May 19, 2026 | 03:08 AM
Hunty60408's Avatar
IIRC the auxiliary heater pump only comes on when engine coolant is above a certain temperature - so it should not be creating a sploshing noise when the engine is cold.
Old May 19, 2026 | 04:37 AM
michaelh's Avatar
I've read that somewhere, but mine always seems to come on with the ignition. Not cold enough?
Check F15 (10A) in the engine compartment fusebox, and, as per Hunty's suggestion, F3 (5A) in the same fusebox. If it's the latter, then the Active Sounder (behind RHS headlamp under the liner) is probably dead and can be disconnected.
Old May 19, 2026 | 05:48 AM
Gerard's Avatar
THank you all, I left the car running to warm up to check the heater hoses as Richard suggested and the heater started working, I guess there must have been an airlock. But all good now thank you all!
Gerard
Apr 12, 2026 06:01 AM
Pistnbroke
Jan 7, 2022 02:52 AM
Wingrider
Jan 9, 2018 01:10 PM
Gerard
Feb 9, 2015 07:37 PM
leewatkinson
Nov 14, 2013 06:25 AM
