2000 XK8 convertible - Need to replace/repair left kick panel
Old Aug 28, 2013 | 04:55 PM
dsjohn's Avatar
Default 2000 XK8 convertible - Need to replace/repair left kick panel
My driver’s side kick panel (cashmere-trim SDZ) has beencracked in several places. I believe the cracks were caused by the dealership in2007 when replacing the hydraulic latch hoses for the convertible top which Iam replacing again. I have searched the Forum, Google, and eBay to try andlocate an intact one to replace the damaged one. Is there any suggestion as towhere I can find a left kick panel? In addition,are there any best techniques to repair the cracks in the kick panel if onecannot be located?
Old Aug 28, 2013 | 05:27 PM
WhiteXKR's Avatar
If you cannot locate a used one in the correct color, consider redying one of another color with the correct leather dye.
Old Aug 28, 2013 | 06:32 PM
Do you mean this ABS panel (this is my RH side panel)?
2000 XK8 convertible - Need to replace/repair left kick panel-dsc_0293.jpg
2000 XK8 convertible - Need to replace/repair left kick panel-dsc_0294.jpg
If so, have the cracks affected the fixing points?
Old Aug 28, 2013 | 07:25 PM
WhiteXKR's Avatar
For some reason I was thinking knee bolster, not kick panel. If it is the plastic kick panel as illustrated by GGG above, your cashmere interior was paired with a darker color below called sable, code AEK.
The part number you need is therefore HJA1381ADAEK. If Jag still stocks it you can get it new here: http://www.gaudinjaguarparts.com/par...w=21&maxRow=10
Old Aug 29, 2013 | 01:21 PM
dsjohn's Avatar
Thanks, they were not able to locate the kick plate anywhere and the same with the dealership here in Tampa...
Old Aug 29, 2013 | 02:48 PM
70z28's Avatar
I have a 2nd hand 1 but its cream
99xk8guy
Sep 29, 2025 10:51 PM
kelliott
May 31, 2022 05:26 PM
XJsc-guy
Nov 23, 2015 01:56 PM
obwoodie
Sep 3, 2015 07:45 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
