2000 XK8 Starting/Sensor Problem
Old May 17, 2023 | 05:23 PM
Chris Lutz's Avatar
Default 2000 XK8 Starting/Sensor Problem
Hello,
Ever since I've owned my 2000 XK8 (almost 3 years), it's had an intermittent starting problem which never seems to happen when I'm at the shop, but almost always happens when I'm home.
About 80% of the time, mostly when the car has been sitting for over 2 days, the car will do a system check when I turn on the power and it will run the following error messages 1) Trac Control Fault 2) Gearbox Fault 3) ASC Fault 4) Restricted Engine Performance. When this happens, I cannot start the car. However, EVERY TIME, this condition will fix itself on its own in anywhere from 30 seconds to 20 minutes. You will here something behind the gauge cluster "turn on," then the warning messages will go away and I can start the car and everything's fine. I can't seem to get a shop to figure it out, as it never happens when it's at the shop, so there is nothing to diagnose.
Any thoughts on what may be causing this annoying problem? Thanks!!!
Old May 17, 2023 | 05:38 PM
barnter's Avatar
Originally Posted by Chris Lutz
Hello,
You might start by checking the state of the battery and the connection to ground in the trunk. Also, other exposed ground connections could be an issue.
Old May 17, 2023 | 05:44 PM
Chris Lutz's Avatar
Thanks. Battery is only about a year old and I run a battery tender on it, but I'll check the ground connections.
Old May 17, 2023 | 06:17 PM
barnter's Avatar
You could also try removing the instrument pack (videos available) and try taking a look at those connectors. Not sure that will help but may be worth a try.
Old May 17, 2023 | 06:19 PM
barnter's Avatar
You could also try scanning for pending codes.
Old May 17, 2023 | 09:03 PM
motorcarman's Avatar
I will post it again!
Check for the RECALL/SERVICE ACTION.
jamesjaguar98
Feb 6, 2023 09:31 AM
jag67
Sep 21, 2019 02:03 AM
tonyforman
Jul 23, 2018 01:06 PM
tspinosi
Aug 4, 2014 10:32 AM
mcleist2
Jul 27, 2011 08:02 PM
