2000 XKR MAF sensor
His problem is high + fuel trims on both banks.
This is his trims....................
2379 rpm ...engine temp 183f...closed loop..
Bank 1 STFT..+0.8
Bank 1 LTFT.. +17.2
Bank 2 STFT..--0.8
Bank 2 LTFT.. +18.0
650 rpm...engine temp 192f...closed loop...
Bank 1 STFT..+0.8
Bank 1 LTFT.. +3.1
Bank 2 STFT..--0.8
Bank 2 LTFT.. +3.1
Bank 1 STFT..+0.8
Bank 1 LTFT.. +17.2
Bank 2 STFT..--0.8
Bank 2 LTFT.. +18.0
Bank 1 STFT..+0.8
Bank 1 LTFT.. +3.1
Bank 2 STFT..--0.8
Bank 2 LTFT.. +3.1
Bad MAF? Fuelling problem (blocked filter, failing pump, ...)? Maybe an exhaust issue?
There is a really good thread by RAZORBOY on the same problem you seam to be having..
Do a search and take a look
Keep us informed of your progress with this issue if possible, As this help's others with similar problem's ..........
AlexJag
Mar 22, 2017 01:41 PM
carguy101
Jun 18, 2014 08:19 AM
