2000 XKR MAF sensor
Old Apr 25, 2019 | 11:13 AM
JagV8's Avatar
Originally Posted by XKR-DAY
His problem is high + fuel trims on both banks.
This is his trims....................
2379 rpm ...engine temp 183f...closed loop..
Bank 1 STFT..+0.8
Bank 1 LTFT.. +17.2
Bank 2 STFT..--0.8
Bank 2 LTFT.. +18.0
650 rpm...engine temp 192f...closed loop...
Bank 1 STFT..+0.8
Bank 1 LTFT.. +3.1
Bank 2 STFT..--0.8
Bank 2 LTFT.. +3.1
Well they're weird. Not an air leak or they'd be high only at low revs instead of at high revs.
Bad MAF? Fuelling problem (blocked filter, failing pump, ...)? Maybe an exhaust issue?
Old Apr 27, 2019 | 01:14 AM
XKR-DAY's Avatar
There is a really good thread by RAZORBOY on the same problem you seam to be having..
Do a search and take a look
Keep us informed of your progress with this issue if possible, As this help's others with similar problem's ..........
AlexJag
Mar 22, 2017 01:41 PM
scardini1
Mar 9, 2016 01:41 PM
powerhouse
Aug 1, 2014 12:25 PM
carguy101
Jun 18, 2014 08:19 AM
Donzi
Mar 1, 2008 06:58 PM
