2000 xkr wont turn over gauges go crazy
Old Jan 2, 2014 | 08:50 AM
divetdan's Avatar
Default 2000 xkr wont turn over gauges go crazy
I am new to Jags. I went to start the car and it would not turn over. the instuments were going crazy and the wipers were moving in a jerking motion. the window went down about an inch and I was lucky to get them to go back up. it kept running fault codes. I was using the green valet key. is this something to do with engine immobilizer? it ran fine two days ago thanks
Old Jan 2, 2014 | 09:07 AM
WhiteXKR's Avatar
Have your battery checked for free anywhere they sell car batteries. These cars will behave very erratically with a weak battery.
PS: Next time please post in the 1996-2006 XK8/R forum...this forum is for the later models.
And welcome to the forum!
Old Jan 2, 2014 | 09:18 AM
divetdan's Avatar
thanks. so should I try to jump start the car or trickle charge it?
Old Jan 2, 2014 | 09:25 AM
I have moved the thread to the XK8/R section for better visibility/response.
Old Jan 2, 2014 | 09:26 AM
WhiteXKR's Avatar
Jump starting this car with a very weak battery can sometimes cause damage. Charge the battery instead. Then, once charged, disconnect the battery for a minute and reconnect it to reset all the computers.
Old Jan 2, 2014 | 11:45 AM
divetdan's Avatar
Default 2000 xkr wont start
thanks I will remove the battery and put it on the charger and will replace if it is bad thanks for the help!!!
Bcrary3
Sep 12, 2021 05:41 AM
Skeeter
Sep 17, 2015 08:15 PM
obwoodie
Sep 3, 2015 07:45 PM
Bcrary3
Sep 3, 2015 03:48 PM
colorancher
Sep 3, 2015 02:29 PM
