2001 Radio Code
Old Jan 21, 2025 | 05:39 PM
OCJoeR's Avatar
Default 2001 Radio Code
Apparently I’m going to have to do a hard reset of my computer system in order to reset the monitors and then go through the “drive cycles” AGAIN so I can get a smog check. I’ve gone through the radio manual but can’t find the reset code. I’ve seen some posts that say some U. S. cars don’t have a reset code but I don’t want to do a reset and be left with no radio. Anyone know if this car needs a code or not?
joe
Old Jan 22, 2025 | 06:37 AM
Hell-Cat's Avatar
Hi Joe, I have a 2001 NA and that doesn't need a radio code, I've had the battery disconnected for several days on many occasions and the radio fired right up on battery reconnection.
Old Jan 22, 2025 | 08:21 AM
OCJoeR's Avatar
Thanks Hell-Cat. At least that's one thing I don't have to worry about. Now if I can just get these monitors to clear I can get this thing smogged.
Old Jan 22, 2025 | 11:13 AM
Y2KJag's Avatar
Confirming that the US spec cars don't have radio codes. I've disconnected my battery loads of times with no ill effect, radio-wise.
Old Jan 22, 2025 | 11:47 AM
motorcarman's Avatar
A radio head unit will require a code IF.................
The radio frequency/country setting is changed from US/North America or......
Certain settings are changed with the SELECTING RADIO FEATURES.
Most will not require the code but SOME DO. I don't remember what one's do or do not.
Be careful when changing settings.
If you have the radio code there is nothing that cannot be UNDONE.
Old Jan 22, 2025 | 12:02 PM
cjd777's Avatar
MY 2000, built on 12/24/1999 has the radio code and had the card in the packet that contained the drivers manuals.
I had to use it a few times but the last time I put in a new battery.
it came right back. Go figure.
Old Jan 22, 2025 | 05:06 PM
OCJoeR's Avatar
Well then it's full speed ahead with disconnecting the battery to reset the systems.
Old Jan 22, 2025 | 07:18 PM
JagWRLD's Avatar
If you do end up needing a radio code, just call Jaguar. They will look up the last several digits of your VIN and can give it to you. Best of luck!
TrevLevin04XKR
Mar 28, 2022 02:44 AM
Dan Dingman
May 27, 2021 02:28 PM
Lady Penelope
Jan 8, 2018 01:39 PM
fingers
May 27, 2016 11:04 AM
Norri
Oct 15, 2007 08:47 AM
