2001 XK8 ASC, Trac and failsafe engine mode errors
Old Aug 24, 2021 | 09:21 AM
Mitro's Avatar
Default 2001 XK8 ASC, Trac and failsafe engine mode errors
trac not available,asc not available and failsafe engine mode
Above errors came up and next day they were gone
Also a coolant error message keeps popping up
eveb though the antifreeze is at full level
A mechanic suggested to change the battery
but i don’t know if that is the right call
Any help would be appreciated
Old Aug 24, 2021 | 09:57 AM
As you have already posted an Intro......
https://www.jaguarforums.com/forum/n...siasts-249033/
....... I've moved your question from New Member Area - Intro a MUST to XK8/XKR forum.
Old Sep 13, 2021 | 05:02 AM
Mitro's Avatar
Hello Graham
i did not get any replies to my posting
can you repost it and see if it is posting
correctly ?
Old Sep 13, 2021 | 05:18 AM
baxtor's Avatar
May be a battery issue but could also just as likely be a solder joint issue in your abs module along with a real or sensor issue with your cooling system.
Old Sep 13, 2021 | 01:09 PM
motorcarman's Avatar
The display is telling you SOMETHING is wrong but you will need to read the DTCs for the reason the modules are flagging the faults.
Please post the actual code(s) for the ECM and ABS module.
pomosv
Oct 11, 2021 02:12 PM
Uk_in_NY
Feb 20, 2021 01:38 PM
Steve W
Jul 7, 2017 05:26 PM
flay
Aug 19, 2013 01:18 PM
one guy
Jul 12, 2011 10:50 PM
