2001 XKR cooling fan stays on
Old Mar 28, 2008 | 12:28 PM
badmojo's Avatar
Default RE: 2001 XKR cooling fan stays on
The cooling fans will stay on for a certain amount of time even after the car is shutoff if it's hot enough. All my Jags. have opperated this way. This is normal however if they come on early and stay on too long then thats a problem. My STR was doing it in the middle of winter and it turned out to be the thermostat. Thermostat and water pump were replaced and no more problems. Hope this helps.
Old Mar 28, 2008 | 04:25 PM
ken@britishparts.com's Avatar
You could change the sensor. It's an expensive guess and prone to fail.
Old Mar 28, 2008 | 07:26 PM
FactoryJaguarTech's Avatar
Regardless of what your service rep says, get the t-stat changed. If fans are running long after vehicle shut off, 99% of time is thermostat sticking.
Old Mar 28, 2008 | 09:24 PM
jag_genius's Avatar
2nd that
Old Mar 29, 2008 | 01:10 AM
Keith's Avatar
Another thing. The fans are designed to come on after engine is shut off to prevent buildup of heat. Could be malfunctioning, but, maybe its finally working right. If all things check out, of course.
Old Mar 29, 2008 | 02:27 PM
Normally if the raditor is blocked, the pressure will suck in one of the radiator hoses, looks flat instead of round. The pressure cap on expansion tank can make it look like the same thing too. Your problem almost certainly sounds like thermostat. On hottest day fan should not run for more than 2 minutes after shut off. Normally 30 seconds will be max.
Old Mar 31, 2008 | 04:53 PM
Max's Avatar
Max
Had the same problem with ours last fall. Turned out to be the plastic vanes on the waterpump, which supposidly was replaced 18 months before, were down to a nub. Installed a waterpump with metal vanes and a new thermostat which stays open if it fails.
Old Apr 1, 2008 | 02:26 AM
badmojo's Avatar
My temp. jumped around and the fans ran before I had the thermostat replaced. Now all is good. Mine was stuck closed so the faster I went the hotter it got. Only turning on the heat would bring it back down which is also another thing you could try when it over heats just to see if it helps.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
May 28, 2024 09:36 PM
jehart49
Sep 12, 2015 05:36 PM
skadmiri1
Sep 9, 2015 11:27 AM
1100me
Sep 7, 2015 06:26 AM
