2002 Jag XK8 radio says no cd when I try to play one, have a cd 6 disk unit built into trunk...Is there a fuse ( I can't find it) radio and casette working fine. Thanks for assistance.
H20boy
close
- Join DateMar 2007
- LocationOak Ridge, TN
Liked:1,164 Times in 761 Posts
Probably just needs a good cleaning. Check out the FAQ thread at the top of this xk8-xkr subforum, and look for a link to cleaning instructions...yes, you'll have to take it apart. Welcome, new guy.
Had exactly the same problem on my 04 XK8 that I just picked up last week. before buying the car I went over _everything_ with a fine tooth comb but never bothered to put a CD in the changer! Followed the instructions and it now works great. In the process, I discovered that my car has the premium sound package that I was not aware of when I purchased the car. A great day thanks to this great forum.
H20boy
close
- Join DateMar 2007
Hmmm, its not in the FAQ, my mistake. It should be, however.
This thread should help -> https://www.jaguarforums.com/forum/x...changer-38681/
https://www.jaguarforums.com/forum/x...no-disc-27536/
and a pdf of the process from the 2nd link above. Good luck.
tberg
close
- Join DateApr 2011
- LocationLos Angeles
Liked:2,623 Times in 1,438 Posts
Have had the same problem a couple of times in three years. Just go to the trunk, eject the cartridge with cd's, and pop back in, and it should return to normal.
Thanks so much for your help! Kathy
