2002 XKR transmission
Old Feb 16, 2012 | 04:57 PM
Captain Kana's Avatar
Default 2002 XKR transmission
My wife's jag had a transmission leak. A drop the size of a nickel everyday. I got a new gasket, and had it replaced. I had also purchased the pan, but we did not need it. So it was returned. This if the Mercedes 722.6 transmission.
The problem is the leak is back. Any suggestions? Could it be the sleave? I am not sure that applies to this transmission.
Old Feb 16, 2012 | 06:07 PM
WhiteXKR's Avatar
Yes, the Mercedes transmission also has a connector sleeve, and it is a common leak point.
Old Apr 1, 2012 | 01:46 PM
Does anyone know what parts I need to fix a leak at the sleeve for a 2002 xkr's mercedes 722.6 transmission?
I would guess at least the sleeve itself and will a mercedes dealer have it?
Do I need to get the transmission gasket also, I know the mercedes dealer carries it?
I have the fluid and I have a mechanic who will do the repairs if I get the parts.
Thank You for your help,
Dan
Old Apr 1, 2012 | 05:45 PM
Cerberus66's Avatar
I have the same issue with my SRT8 thatuses the same tranny
Old Apr 1, 2012 | 06:43 PM
WhiteXKR's Avatar
It is Mercedes pn 2035400253
Also avaialble here: Mercedes Adapter Plug With O-Rings Transmission Cable to Conductor Plate NOTE: O-Rings are no longer available Separately. 2035400253 - RM European Auto Parts
Or just get parts for an 2003 SLK230 transmission from a Mercedes dealer...one of many Mercedes models with this transmission.
Old Apr 1, 2012 | 09:58 PM
motorcarman's Avatar
Here is the old TSB that was issued in 1999
bob gauff
File Type: pdf
Old Apr 2, 2012 | 09:32 AM
Thanks White XKR and Motorcarman, you both gave me just what I needed.
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
way2far
Aug 31, 2022 09:26 AM
Dicque
Sep 19, 2015 12:53 PM
Numwen
Sep 6, 2015 12:30 AM
