2003 XK8 4.2L cranks but no fuel
In need of some help here, shut car off and would crank but not start. Replaced fuel pump still no start. found no power after initial key on when cranking. No codes from ECM. Verified Ignition spark, replaced cams sensors, crank sensor and inertial switch along with fuel pressure sensor and fuel pump control module. No change in car. Shipped ECM to rebuilder in Jacksonville and was told it was done and would have to be replaced. They offered a reman but no programming available to them. I am struggling to know what can be replaced to get vehicle to run without additional programming. Many different answers from folks, thought I would ask the seasoned vets on here. If the speedo, ECM, BCM and ignition key/module from same donor vehicle is all installed at the same time, is additional programming needed to make car run? My availability here in the Florida Panhandle have netted poor results. This was my late wife's prized possession and I would love to get it back up and running. The car only has 107K miles on it and is in pristine condition. Many thanks in advance for all of your help and assistance.
Before buying such, maybe there's hope. I'm very surprised to hear about the "ECM" as they are very robust.
Have a look for posts about the PATS light.
Also, what codes are there? You should at least have one of P1000 / P1111.
Don't take this the wrong way, but stop firing the parts cannon at it. That approach almost never works.
How much diagnosing was done? When it first failed, did you check fuel pressure before replacing the pump? After? How do you know you have spark? You can't have spark if you have a bad ECM. Or if the anti-theft has immobilized you.
Fuel pump will run for 1-2 seconds after the key is turned to position ii (on)
Do you have B+ on the injector Black/Red wire(s)? Check F18 (10A) in the Engine Management fusebox.
Module replacement is much more involved on the 4.2L cars. See the attachment on this post from motorcarman:
https://www.jaguarforums.com/forum/x...8/#post2719259
Which modules have you changed, and do you have the originals?
All original modules are still on the car. I have checked all fuses in all boxes and non have been blown. Will check B+ on injector wire as recommended when I get home today, will let you know what I find out. Thank you for the assistance, I greatly appreciate it.
It would be worth just looking inside the fuel tank again to make sure all is well. I had a fuel pump failure recently, fitted a new one and still had no fuel pressure. Turned out that the output hose had come off the pump, despite me being certain it was securely attached. The new pump was running, but just squirting fuel around the tank. One thing I did notice was that after each crank attempt, there was pressure in the tank, and a whoosh as I removed the fuel cap, presumably as a side effect of the pump running. Might be worth just checking for similar.
Smokey59
Jun 13, 2023 07:15 AM
Eric's XJR
May 17, 2022 08:16 PM
sayitaintso
May 25, 2016 09:32 AM
