2003 XKR sun visors will not fit back after Removal
Old Jan 17, 2023 | 04:23 PM
andymac66's Avatar
Default 2003 XKR sun visors will not fit back after Removal
I recently replaced the headlining on my car with a new one from Headlining World. I have been struggling for a few weeks now to refit the sun visors. The problem is, when I screw in the two screws holding up the sun visor bracket into the roof and then clip in and screw up the plastic catch on the other end, they never line up and the end of the sun visor will not locate in the plastic catch. The sun visor seems to be around one centimeter too long! Does anyone have any ideas what the problem could be?
Old Jan 18, 2023 | 02:07 AM
PKWise's Avatar
Unusual problem. The inner brackets are located directly into rectangular holes in the roof panel - so not much movement variation (I don't think it can be these).The outer bracket screws locate into double roof clips that can move around a little. The clip type is visible in far left and far right of image. Be very careful when forcing these clips because if they disengage, then they can fall into a void between panel skins - which goes down inside the A-Pillar....
Old Jan 18, 2023 | 03:23 AM
tsuppari's Avatar
Install this end first properly and check if another end still is issue.
Old Jan 18, 2023 | 04:02 AM
andymac66's Avatar
Thanks for your suggestion. Do you have any idea how I could install this end differently? The holes in the metal roof line up perfectly with the holes in the roof lining and I've screwed the bracket directly into them. The bracket in this photo does not appear to be misaligned. The plastic cover is hanging loosely as I suspect I will have to take the visor off again. It does not affect the positioning or alignment.
Old Jan 18, 2023 | 04:12 AM
andymac66's Avatar
Thanks for the photo. It's good to see what's behind the headlining without having to peer in with a torch. I had spotted the metal clips for the self tapping screws - in fact one fell off when I took the old heading down. I put it back in the correct place so that's not the source of the problem. Actually I have the same issue with both of the sun visors. I can't get either of them to clip in to the fitting at the end.
Old Jan 18, 2023 | 08:23 AM
tsuppari's Avatar
Here is video about X100 visors in general. Weird issue. I re-holstered my inner roof last winter and had no issues fitting visors back.
Old Jan 18, 2023 | 09:31 AM
Dr. D's Avatar
I recovered my header in 2013 and again last summer. I am baffled in that I do not see anything wrong with your installation. I am looking forward to someone discovering the missing puzzle piece / pieces!.
Old Jan 18, 2023 | 10:39 AM
michaelh's Avatar
The clip looks to be at an odd angle. It should fit more snugly into the headlining and depress it slightly. From memory, this clip has a square 'peg' arrrangement at the back that is splayed when the retaining screw is inserted.
The pivot end looks fine.
If you look at PKWise's pic, you will see the square hole it fits into, with a depression around it.
Here's a pic of mine. It's possible to see the clip has sunk a short distance into the headliner:
must give that a clean next time I'm in there...
edit; Just a thought - the headliner backing should have a hole rather larger than the size of the 'peg', to allow the clip to snug down against the metal header rail behind. Is that the case on yours?
Old Jan 18, 2023 | 03:51 PM
andymac66's Avatar
So am I! It's really annoying me
Old Jan 18, 2023 | 04:11 PM
andymac66's Avatar
Thanks Michael, you may be on to something there. I think the plastic clip could be the culprit as the screw holes on the pivot end line up perfectly with the headlining and the holes in the metal roof. I had noticed the angle of the plastic clip and I know what is causing it. The hole in the headlining at this point does not align completely with the hole in the roof metal underneath. That is causing the clip to go in at a tilted angle and yes, it is being forced away from the contact bar on the sun visor. I find it hard to believe the hole in the headlining is in the wrong place but I suppose it's not impossible. I will try loosening the sun visors and see if I can move the headlining enough to center the hole in it with the square hole in the roof metal - but without taking the sun visors off. Your photo showing how the plastic clip should be sunk slightly into the headlining was an eye opener for me. I need to push it further in so that it sits straight. That should hopefully bring it into alignment with the contact bar on the sun visor. The only question is, will the hole in the headlining allow me to do that? I'll give it a try tomorrow. Thanks for your help!
Old Jan 18, 2023 | 05:24 PM
michaelh's Avatar
Hopefully you will be able to juggle the headlining around enough to get everything to line up once the screws are loosened, if that doesn't compromise the pivot attachment, which looks just fine.
Failing that, you do have some latitude to enlarge the hole slightly as it will cover with the clip. It's entirely possible that the replacement board isn't formed exactly.
The last time I did this, the local car restorers said it was better to recover the original backing rather than use a pattern part as they had had fitting issues in the past, although I don't know where they sourced their replacements.
So, they re-covered the original backing, together with the A-pillar covers and parcel shelf while the car was in pieces. I'm very pleased with the result, although it was hideously expensive compared to a pattern part. I suspect it would have been about what Jaguar would have charged for a new OEM, had they still been available.
It's not a task you want to be doing too often
Good luck!
Old Jan 19, 2023 | 09:58 AM
Dr. D's Avatar
Good luck!
Mike:
I should have picked up on the clip being at an angle. (I will again use my eyesight as a crutch)
In fact, the first time I did mine, I had access to a laser and cut these steel clamping pads to use on those indents while the adhesive setup.
Old Jan 19, 2023 | 10:07 AM
michaelh's Avatar
Curious:- so you did the re-covering of the fibreglass backing yourself?
Apologies Andy for the OT
Old Jan 19, 2023 | 10:25 AM
Dr. D's Avatar
Yes.
FWIW, here is a cut and paste of my notes:Take existing photos if necessary
overthick matl 3/16" standard is 1/8" (watch for grain direction if necessary)
use pool table to square up cloth, straight edge, perm marker, tri square
(2) Pillars 8" X 24"
(1) Header 13" X 60" (54" min width)
-- mag tray for hdwe
Rmv pillar covers with large screwdriver at 3 white dots on backside blk rubber weatherstrips(my cheat marks). My Passenger side sensor post is broken, be careful and elec conn , remove 1 sensor screw, washer only.
Rmv Header pull ovhd console straight down(old plastic brkt may break)---visors first small flat blade for screw covers (make sure the two overhead conn are in their holders before reassy)
rmv visor elec receptacles-use straight pick to unhinge scr covers, rmv scr each side.
pull header straight down at receptacles just far enough to disconnect visor elec conns
Remove old cloth
Rub off old foam by hand,or scrape
wet 25 sq in area / laquer thinner (work in small areas)
scrape glue while wet with knife blade--discard residue on blade
wipe with laquer thinner soaked rag
Use 3M headliner spray (do not 3M 77 or old spray
Try to avoid and watch out for possible adhesive strings wrapping around onto finished side (use fine sewing needle to pick off)
Do pillars first (know adhesive tack time)
lay cloth face down on clean surface
place pillar cover face up centered on cloth
spray cover only (min overspray may be on foam)
lay aside cover and spray the foam side of the cloth
(do not be concerned with wrap around at this time)
Pat cloth from center out (do not poke with finger)
cut margins and cut form darts (stop dart cuts before edge 1/8"-3/16")
spray (brush) wrap around (do not concentrate force on face side(ie finger poke))
Header
Mark centerline on foam side of fabric
remark ctrline of header if necessary
place header face up on covered sawhorses
center fabric atop header-foam side down
fold left side of matl back on right side being careful to keep location
spray left side of header (top face only--not side wraps yet)
spray mating foam
Do right side similarly
( Plastic clamps (4)laser cut visor pads (2 mounting plcs & 2 visor receptacles )
starting at ctr line, glue rear (top latch side)side wraps later
then in turn do front side wraps
cut margins and cut triangular form darts (stop dart cuts before edge 1/8"-3/16")
spray (brush) wrap around (do not concentrate force on face side(ie one fingertip))
use straight pick thru ctr all holes, 2 slots
use x-acto knive blade to cut "X" in holes slots
fully cut out airbag sensor hole
Old Feb 6, 2023 | 06:02 PM
andymac66's Avatar
I finally managed to get the headlining up and it's looking great! I had to file out the driver's side hole in the head lining for the plastic sun visor clip to make it line up with the hole in the metal roof. I was able to get the map light up with a reassuring click by moving some thick wiring out of the way which had been stopping the clips from fully engaging.
Old Feb 6, 2023 | 06:50 PM
Dr. D's Avatar
Andy, glad it's back together OK
Mike, sorry that I did not pickup that we were talking coupes..
I have never done a coupe as in my area,, it was cheaper and better to pay a pro.. I think I paid $85 to redo a T Bird coupe in the late 80's!
Old Feb 7, 2023 | 05:35 AM
michaelh's Avatar
Andy - glad you got there. It is a job.
Mike, sorry that I did not pickup that we were talking coupes.!
LOL & I should have clicked that you would have a convertible. 15-All.
streamsaver
Oct 28, 2018 10:36 AM
Long Islander
Aug 30, 2016 05:08 PM
dartweb
Sep 21, 2013 05:57 AM
dtomaso1
Jan 20, 2013 11:09 PM
