2004 XK8 - ZF 6HP26 questions.
Old Nov 1, 2019 | 08:28 PM
nalle's Avatar
Originally Posted by ccfulton
The adaptation drive cycle is a very particular thing, no normal human would ever drive a car the way you have to to successfully complete the cycle. You have to be super gentle, keep the throttle in a very narrow range and a particular speed when the shifts occur.
That's why I say if you are going to do it, then it's best to have a ride along to manage the laptop and trigger the steps and to find a very empty piece of road.
Yes, I understand. I have seen a BMW video on the process. Also learned today that British Automotive in Scottsdale claim to be able do it. They say it is about a two hour job. Have not talked to them myself yet. It's for down the road after the oil change. I had the oil change planned for this weekend, but back problems will make me hold it off for a week. Maybe the bluetooth install instead this W/E?
I do have the iCarSoft unit that can read tranny oil temp. Seems a lot easier to just use a IR gun on the bottom of the pan as you are laying down there. Does it make any difference which method you use???
By the way, I say you old post on the surface mount resistors for LED load on rear light. That looks pretty neat (except for the soldering) and will now be on my list of things to do!
Old Nov 1, 2019 | 09:20 PM
Don B's Avatar
The plastic oil pan is a poor conductor of heat, so you can't get a reliable temperature reading on its lower surface. If you use an infrared thermometer, aim the beam at the fluid dripping out of the fill hole. Either a measurement of the dripping fluid or via the trans oil temp sensor should get you close enough for a good fill. I find using a scan tool more convenient in general.
As fmertz reminded, do shift the gear lever through all the positions and hold each one about 3 seconds to fill the valve body and associated passages. I try to do this while the trans is warming up but before it reaches 30C.
Cheers,
Don
Old Nov 1, 2019 | 09:30 PM
nalle's Avatar
Cheers,
Don
Got it! Will probably use the iCarsoft then even though that seems to make it a two person job. One to read the temp and one to get burned putting the plug in!
Old Nov 2, 2019 | 06:11 AM
Jon89's Avatar
The entire ZF ATF process is so much easier as a two-person job. I have done it five times on two different cars (my wife's 2006 XK8 and my former 2005 S-Type) always with at least two people involved (and several times with three people involved). You will be much more precise with the various required steps if you have a partner working with you....
Old Nov 2, 2019 | 08:33 AM
nalle's Avatar
Yes, I would agree with that. Specially dropping the Mechatronics unit seems to require more than two hands. My problem is that my kids are too far away and it will sure take some doing to find someone around here in my age group, in a retirement community, willing to crawl under a car - even if it is a Jag
Miami0913
Jan 7, 2021 03:04 PM
kirkls
Jul 30, 2018 11:01 AM
spiccot
Nov 18, 2014 11:06 PM
Louenigma
Feb 12, 2013 01:12 PM
ccc
Jan 4, 2010 10:22 AM
