2006 XKR dead battery and can't open boot
Old Mar 23, 2016 | 04:40 PM
KitKel's Avatar
Default 2006 XKR dead battery and can't open boot
This seems to be a common problem since I have looked at several threads. Unfortunately, I am "just a girl" who knows very little about cars. This model does not have a manual keyhole for the boot as far as I can tell. I have seen some posts about alternative methods for charging the car enough to get the trunk open, but none that is specific to this model. Can anyone assist with this? I have seen some "fixes" as simple as getting a charger that plugs into the cigarette lighter, but several people commented that this did not work for them.
Old Mar 23, 2016 | 05:08 PM
brgjag's Avatar
Check in/on/around the JAGUAR XK8 emblems on the back of car, the key hole is there.
Old Mar 23, 2016 | 05:10 PM
brgjag's Avatar
On your model on that back of car in the XK8 emblem the key hole is in the number 8 of Xk8 I think.
Old Mar 23, 2016 | 06:15 PM
woox4's Avatar
Left hand side of the XKR badge
Old Mar 23, 2016 | 06:46 PM
brgjag's Avatar
Ah, xkr, I missed that.
Old Mar 23, 2016 | 10:15 PM
Ungn's Avatar
It's us early guys that need to "jump" our trunks. The later cars can use a key.
Old Mar 24, 2016 | 08:20 AM
reb1999's Avatar
Another method, in case, some trickle chargers have a cigar lighter charging hook up. With time enough to pop the lid...
Old Mar 24, 2016 | 10:46 AM
MRomanik's Avatar
Veteran: Air Force
My '97 has key access to the trunk.
Old Mar 24, 2016 | 12:09 PM
Ungn's Avatar
It shows that in my Owners manual that is original to my car. The guy designing the trunk look must have missed the launch deadline.
Old Mar 24, 2016 | 10:19 PM
rperformance's Avatar
When you do get into the trunk. ... DO NOT try and jump start the car. That can cause all kinds o electronic module problems. Disconnect the battery and then charge it.
bjmawg
Oct 10, 2022 06:13 AM
milleniumaire
Oct 1, 2020 05:59 PM
spookybzn
XF (X260)
Apr 1, 2016 05:54 PM
Metaxalone
Mar 15, 2016 03:24 AM
Old_Doc
Feb 25, 2016 01:23 PM
