4.0 to 4.2 engine swap update
I have almost completed the engine swap project. The motor in in and running. Just have a vacuum leak to run down tomorrow. I do have a lot of motor parts left over. If anyone needs any of them, they may have them. Just let me know what you what you want and I will look. Thanks for all the great info on this forum. I never would have tried it with out all you folks helping. steve in cape coral.
I did the swap because the 4.0 motor was toast. There was a lot of medal in the oil pan and no compression. The 4.2 motor has a lot of improvements and made sense to change. There are several post on this site about doing this. There are some things I ran into that took a little redoing, but most of it is covered by the post. I don't know about the swap on a XK8.
If you have plenty of funds, time, and don't give up easily, it might be possible. The usual answer is... buy a factory XKR
I have none of those, I was just wondering. I wasn't aware it is possible to go from a 4.0 to a 4.2...
That being said, I was under the impression that the 4.2 engine is actually slightly less powerful than the 4.0. Could anyone confirm if that's true?
What are the HP numbers?
I thought the 4.0 NA is 290 HP at 290 lb-ft of torque and the supercharged 4.0 is about 380 HP and lb-ft of torque, give or take. However, I'm not aware what the numbers are for the 4.2 engines.
Just to let you know, I have to date spent $1676 including motor, freight, gaskets, bolts degreaser, timing tool set, oil pickup tube serpentine belt, oil and filter. Still have to get antifreeze. The motor produces a lot more hp than my stock 2003 Xk8. All the info to do the job was found on this forum and on the internet. I did this swap in my garage at home and I am not a professional mechanic, just a hobbyist. I would love to buy a new xkr, but anybody with money can do that. My way has real satisfaction in knowing I am keeping another of these fine cars from the scrapper. steve
KarimPA
Sep 3, 2015 07:32 PM
