4.2l XKR/XK8 TRANSMISSION HELP
Old Mar 6, 2026 | 08:25 AM
Sethharttt's Avatar
Default 4.2l XKR/XK8 TRANSMISSION HELP
I’m looking to put a low mile 2005 XK8 transmission into a 2004 XKR. Are there any differences between the two ZF6HPs? Are the torque converters and valve bodies the same? Thank you!
Old Mar 6, 2026 | 08:46 AM
clubairth1's Avatar
Community Influencer
I would not put a non-SC transmission into a SC version. Yes there are differences between them.
When working with the 6 speed ZF the metal tag on the transmission needs to match.
This is the tag your looking for on the transmission case.
Next there are also variations in the valve body and they also carry a serial number.
So see if you can find your tag and get the numbers off it. I would look for a SC version.
Old Mar 6, 2026 | 10:55 AM
zray's Avatar
What’s wrong with the existing transmission ? (Sorry, I’m just a curious person),
Z
Old Mar 6, 2026 | 11:34 AM
michaelh's Avatar
They do have different Jaguar part #s, although I have no idea what the differences may be.
Old Mar 6, 2026 | 11:41 AM
motorcarman's Avatar
Be aware that the Valve Body (mechatronic) contains the TCM.
To keep the VID block 'happy' I would use the original TCM swapped over to the replacement unless you plan on attempting to reconfigure the replacement.
Old Mar 6, 2026 | 12:09 PM
Sethharttt's Avatar
Z
No issues, I have an AVOS KB kit and I figured I should go through everything if I was going to throw it on! I’m already around 156,000 miles. Buying an entire XK8 is cheaper than going through the trans that’s already on the car. I’d throw in a low mile donor transmission and part the rest out.
Old Mar 6, 2026 | 12:36 PM
Don B's Avatar
I believe the difference in the XKR and XK8 transmissions is that the Mechatronics/TCMs are programmed differently. Following Bob's excellent advice to use the original Mechatronic should resolve this issue.
While you're doing the Mechatronic swap, replace the valve body bridge seal and tubular seals, and the electrical connector sealing sleeve, since they all deteriorate with age despite mileage.
Cheers,
Don
Old Mar 6, 2026 | 01:14 PM
Jon89's Avatar
^^ What he said....
Old Mar 6, 2026 | 01:24 PM
Sethharttt's Avatar
Cheers,
Don
Thank you! By any chance would you happen to have the link to them? I’m having trouble finding the parts online. Much appreciated
Old Mar 6, 2026 | 02:21 PM
Don B's Avatar
I used to get them from California Transmission Supply Co. (thectsc.com), but their site has gone down. FCP Euro carries the electrical connector sealing sleeve, ZF part number 24347588725. I don't see the valve body seals. If no one else posts those part numbers before tonight I'll look them up.
Cheers,
Don
Old Mar 6, 2026 | 06:51 PM
Don B's Avatar
From my records, here are the Jaguar and ZF part numbers, as well as a few for Eriksson, which is a major supplier to professional transmission repair shops (at least in the U.S.).
Sump Pan/Filter: Jaguar P/N: C2C6715 supersedes to C2C38963 ZF P/N 03.010 Eriksson Pan P/N: 1068-298-075
NOTE: The "genuine ZF" pans are made by IBS Filtran GmbH (and are made of LANXESS Durethan AKV 35 H2.0 polymer, if you're interested)
Electrical Connector Sleeve: Jaguar P/N: C2C9645 ZF P/N: 27.520 Eriksson Sleeve P/N: 0501-216-272
Bushing / Tubular Seal / Sealing Sleeve, VB to Case: Jaguar P/N: C2C9653 ZF P/N: 01.050 (NOTE: 2 are required)
Bushing / Tubular Seal / Sealing Sleeve, VB to Case: Jaguar P/N: C2C9654 ZF P/N: 01.060
Bushing / Tubular Seal / Sealing Sleeve, VB to Case: Jaguar P/N: C2C9655 ZF P/N: 01.064
Adapter / Bridge Seal / Rubber Spacer Gasket, VB to Case: Jaguar P/N: C2C12379 ZF P/N: 27.460
The parts are typically a lot less expensive from a ZF parts supplier than a Jaguar parts supplier. Give the ZF supplier your transmission serial number so they can confirm the correct part numbers.
Cheers,
Don
Old Mar 6, 2026 | 07:40 PM
scottjh9's Avatar
I still have this. It is in the marketplace under zf6hp26 trans. It came out of a xkr
if you want more info contact me.
Old Mar 7, 2026 | 10:57 AM
clubairth1's Avatar
That would be a great used replacement!
Motownjag
Jan 12, 2024 11:54 PM
ScoopXK8
Dec 25, 2022 06:43 PM
peterg19
Jan 30, 2015 01:02 AM
Terry
Jul 28, 2009 02:48 PM
