96 XK8 - ABS light not switching off for circa 12 seconds
Old Feb 24, 2013 | 09:54 AM
Frog's Avatar
Originally Posted by steveinfrance
That's a disgraceful idea.
Damn right. Members who countenance that sort of behaviour should be banned.
Old Feb 24, 2013 | 10:04 AM
steveinfrance's Avatar
I can't ban myself - should I ban Jim which will close the whole Forum down ?
Old Feb 24, 2013 | 10:31 AM
batroute's Avatar
UKMOT.com MOT Manual 3.4 ABS Systems
Sorry guys, (although you might fluke it if the tester is not on form that day)
Old Feb 24, 2013 | 11:07 AM
Frog's Avatar
When did ABS become mandatory in the UK/EU? If it was after 1996 - when the OP's car was registered - won't he be ok? I had an engine warning light on my Mini Cooper when I took it for its French MOT last year, but the tester ignored it because it was a 2001. Just a thought...
Old Feb 24, 2013 | 11:35 AM
batroute's Avatar
My understanding is that if the (ABS) system is part of the original fitment(which it was) then it's a testable item. I've been out of fleet management since 2009 so I can't claim to be current on regulations but it would be highly unusual if VOSA took a retrograde step on compliance with a safety item.(or anything else for that matter).Things changed when they became a government agency charged with being self sufficient financially. Last I heard (2009) they were up for privatisation or such like. There may well be MOT testers on this forum who can correct me if I am wrong. I also think there were moves afoot to abolish testing at three years old and carry out the first test at (I think) the fifth anniversary of registration - not that this would help the OP.
Old Feb 24, 2013 | 12:45 PM
MarkyUK's Avatar
Done all except the soldering, however I now have TC/SC control failure as well as the ABS warning light permenantly on, so not as simple removing a bulb now :O(
Will send the unit away to not only have the pump soldering done but an overhall of the PCB...quite cheap at £100
Old Feb 24, 2013 | 12:52 PM
MarkyUK's Avatar
Frog ABS is not a requirement even for new cars just that everything fitted must work.
For example I am looking to fit aftermarket front fogs as one of them is broken...I just removed them completely and therefore no fail.
Would be good to disable it but not terribly safe
Old Feb 25, 2013 | 02:27 AM
  #28
Let us know how you get on. Good luck.
Old Feb 26, 2013 | 12:38 PM
MarkyUK's Avatar
Here's the kicker, not driven it for a couple of days, started up this morning and ABS light switches off after 3 seconds with no TC/SC warning. So drover 3 times and started up another 10 and all ok.
Took for MOT and passed!
Funny foibles these cars have!
Old Feb 27, 2013 | 10:31 AM
  #30
See the advantages of Forum membership ?
If nothing else you've gained sorting-out time.
Old Feb 27, 2013 | 03:14 PM
  #31
MarkyUK's Avatar
Today though ABS light stays on and TC/SC fail messages
What a car!!
Hey now got a year to sort it out before next MOT!
Old Feb 27, 2013 | 05:08 PM
  #32
oyster's Avatar
Hi.
It is not that strange. A bad solder joint in the module, a harness on the way to break or bad connector may give you these symptoms, warning light comeing and going.
99xk8guy
Sep 29, 2025 10:51 PM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
laserguy
Sep 3, 2015 02:02 PM
innzane
Sep 2, 2015 10:08 AM
