97 XK8 Convertible windshield washer reservoir leaking
Old May 26, 2018 | 05:24 AM
Allen/Olivia's Avatar
Default 97 XK8 Convertible windshield washer reservoir leaking
My windshield washer reservoir when filled leaks.
There seems to be two different reservoirs available for this car; I've searched EBay and there are two reservoirs listed for the 97 XK8.
i believe my car uses the reservoir with the long neck. Would someone kindly tell me which tank my car has, and help me with instructions on how to replace it.
Thanks!
Old May 26, 2018 | 06:16 AM
The reservoir difference is Powerwash/Non Powerwash for the headlamps.
(double click on the image to enlarge it)
The assembly is behind the LH wheelarch liner (this is my 2001 RHD. I don't think it's on the opposite side for LHD cars but members with LHD's will be able to confirm.)
97 XK8 Convertible windshield washer reservoir leaking-14-ns-upper-wishbone-abs-wheel-sensor-cable-moved.jpg
A regular fault is leakage from the filler tube so it is worth investigating before buying a replacement reservoir.
Old May 26, 2018 | 07:07 AM
DevonDavid's Avatar
This is my 1997 washer bottle on my rhd car.
Don't assume the bottle itself is cracked or broken unless you are sure - the arrow on my photo points to a joint where a thin rubber tube goes over a plastic spigot. That's where mine was leaking, and a small cable tie (the little white one) around that joint solved the problem.
Old May 27, 2018 | 06:46 PM
Thanks guys!
My XK8 does have the power wash feature.
On my next time home (I'm an over the road truck driver), I will investigate further.
Allen
Old May 28, 2018 | 01:00 PM
Originally Posted by Allen/Olivia
..... I'm an over the road truck driver .....
Learn something everyday here. Had to Google that one.
We have National (within the UK) and International (crossing to mainland Europe and beyond).
Old May 28, 2018 | 01:45 PM
toaster's Avatar
Have you never seen „Convoy“ with Kris Kristofferson?
Stuart S
Oct 18, 2016 03:33 AM
chairman25
Mar 28, 2015 09:20 PM
MTZGR777
Jul 25, 2011 04:58 AM
rogerk
Jun 24, 2010 07:23 AM
Davedz
XJ40 ( XJ81 )
Jun 9, 2010 08:39 AM
