97 xk8 seat switches fried HELP!
Old Jan 26, 2011 | 09:03 PM
smokphattys's Avatar
Default 97 xk8 seat switches fried HELP!
Ive just replaced all the chains and tensioners on my xk8 and moved on to the next problem. the power seats when plugged in will only move forward and down (not so comfortable) i tried swapping the passenger controls and managed to get the seat back to normal but when i switched back the passenger seat did the same. im not going to plug them in until i figure out a fix but i dont know how to get the passenger seat to a normal position in the meantime. I checked the seat module and there does not seem to be any worn connection, however when i took the seat switch appart i found it fried/melted, the same when i checked the passenger side. anybody know how to fix this?
Old Jan 26, 2011 | 09:13 PM
test point's Avatar
I had a seat switch fail and was able to clean and lubricate it back to life. Based on the condition in the photos it is probably time to replace the switches.
Old Jan 27, 2011 | 01:53 AM
XKRacer's Avatar
You can no longer buy those switches from Jaguar! Let alone the cost is high.
You will have to find a breaker that has an XK with tatty seats otherwise they will not seperate the parts (normally). You often find the switches are worth more than the seat, over here you will pay around $120 for them if you are lucky.
Old Jan 27, 2011 | 04:29 AM
Jaxkr's Avatar
I may have one of those switches, in coffee color. I will check for you.
Old Jan 27, 2011 | 07:44 AM
thanks guys, i was afraid of what xkracer said, any colour will do if someone has one, I can always swap out the cover. Im guessing the circuit board cant be rebuilt? any help is appreciated as my passenger seat is not in a good position
Old Jan 27, 2011 | 08:26 AM
Bamaman's Avatar
The passenger seat switch is on the corner of the seat--just where a passenger's left foot can crunch the plastic front switch when they get in. If unavailable from Jaguar, I'm in a heap of trouble, as my seat won't go back.
Old Jan 27, 2011 | 03:04 PM
ya im in the same "position"
Old Jan 28, 2011 | 08:07 AM
any luck jaxkr?
Clamdigger
Sep 12, 2015 03:43 PM
wcourt3010
Sep 9, 2015 04:34 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
laserguy
Sep 3, 2015 02:02 PM
Dallas XK8
Sep 3, 2015 12:17 PM
