98 XK8 radio
Old Jul 25, 2018 | 06:46 PM
drdude21's Avatar
Default 98 XK8 radio
Hey guys! I have a 1998 Jaguar XK8 and I was wondering if anyone has changed the oem radio to a nav/Bluetooth one? If so, what was involved?
Old Jul 27, 2018 | 10:35 AM
brobin's Avatar
I did it on my 98 8 years ago. See this thread: https://www.jaguarforums.com/forum/x...o-today-38499/
I've never been thrilled with the look so I'm thinking about adding this: https://goo.gl/Qv9weK
To do the job you need to remove the shift surround and center console and then the fascia.
Old Aug 1, 2018 | 02:50 PM
drdude21's Avatar
If I was to use that part from eBay, could it fit a nav system? Also, wonderful job on the install man!
Old Aug 1, 2018 | 04:41 PM
darbysan's Avatar
I just went through this research on one of my other vehicles, and found a couple of single din units at Amazon that had small screen. This one may fit, but you would have to measure your dash area- I don't have an XK8 ( yet).
Amazon Amazon
One newer style that I have installed and like is an Android Radio. It has a separate face unit from the actual radio, connected with a flat cable 12" long ( extensions available). They come in different screen sizes. One that interests me is the 8.8" dia. screen, which is about 4.2 x 9.2 in actual size ( about 1/2" thick). I'm thinking of mounting this where the 3 gauges are located, and re-locating the gauges to the radio location. The "new" radio box may fit where the old radio was located, with the extension cable running up to the screen. Would require making a couple of panels ( one for the gauges, one for the screen), but it gets the screen up where you can see it. You can even mount the screen using a couple of MagDaddy Panel Magnets- I tried them and they do not affect the screen. Probably a good time to upgrade the gauges so they are fully functional too! XK8 / XKR / XJ RealGauge - TheJagWrangler
Available direct from Joying, or via Amazon.
Old Aug 2, 2018 | 10:50 AM
brobin's Avatar
The part from ebay will fit a single DIN unit so not sure what the NAV options would be at that size. I rarely use the NAV in my other cars when if I need it my phone generally does the job better.
gotmoss89
Jun 23, 2012 06:26 AM
gotmoss89
Apr 23, 2011 02:16 AM
kdross
Apr 17, 2010 11:11 PM
fidget247
Apr 6, 2010 06:43 PM
LarryK
Jan 26, 2010 01:01 PM
