'99 xk8 conv door panel connectors, and combo turn light switch
Old Oct 17, 2012 | 11:36 PM
midamdoc's Avatar
Default '99 xk8 conv door panel connectors, and combo turn light switch
Where can I find driver door panel plastic connectors: low flat green plastic that hold the connector pins? Do you know part numbeers for pins and connectors?
Suddenly combo turn signal light switch is out of synch( maybe since I removed the driver door panel and door safety light bulb is out). The 4 switch positions are not correct e.g. off is on; auto is off when key if off. Any suggestions? is it programming issue or hardware? Thanks.
Old Oct 17, 2012 | 11:38 PM
stevepaa's Avatar
Can you post a picture?
Old Oct 18, 2012 | 04:07 AM
Originally Posted by midamdoc
Where can I find driver door panel plastic connectors: low flat green plastic that hold the connector pins? Do you know part numbeers for pins and connectors..................
Is it Item 9 (Friction Bush) you need?
There's nine on each door and they were supplied in packs of five the last time I needed replacements.
Attached Thumbnails '99 xk8 conv door panel connectors, and combo turn light switch-door.jpg
Old Oct 18, 2012 | 04:07 PM
midamdoc's Avatar
I think so lastic friction plastic pin on backside of door panel AND the connector that is glued to the back fo panel and holds the pin to the panel.Thanks
Old Oct 19, 2012 | 10:10 AM
midamdoc's Avatar
Default Pictures of door panel connectors I'm seeking'99xk8
[attach][attach][att'99 xk8 conv door panel connectors, and combo turn light switch-302.jpg
'99 xk8 conv door panel connectors, and combo turn light switch-307.jpgach]24980[/attach][/at[attach]24979[/
Old Oct 22, 2012 | 09:43 AM
stevepaa's Avatar
I'd go to a dealer and see if they are available separately from the door panel and then get the part numbers.
Old Oct 22, 2012 | 09:59 AM
mjlaris's Avatar
I need a couple of these for both my XKR and my X-Type but I don't think you can buy them separate from the door panel. If you find a source, please post it here. Thanks,
Mark
Old Oct 27, 2012 | 07:05 PM
midamdoc's Avatar
Calling White XKR he usually knows all the parts numbers.
Old Oct 27, 2012 | 08:15 PM
WhiteXKR's Avatar
LOL, No special powers here....I have the same resources everyone else on the forum has.
The parts are not in the published parts diagram. A dealer might have more information.
If they are not available, if you have the broken bits, the clips can be repaired quite effectively ( I have done it) with JB Weld (regular, not Quick set). Even if the bits are missing, you probably can cobble a repair together with JB Weld and some scrap plastic.
If you really want the originals, then get a used door panel from a breaker or ebay. The clips are attached with hot melt adhesive, so some judiciously applied heat will remove them.
BrentGardner
29
Dec 16, 2024 12:13 AM
aratnam
Sep 18, 2015 09:31 AM
msdg137
Sep 16, 2015 06:24 AM
kesslari
Aug 31, 2015 04:53 AM
Jandreu
Aug 29, 2015 07:31 PM
