ABS Light on after brake refresh
Old Dec 17, 2024 | 07:31 AM
AbnMike's Avatar
Default ABS Light on after brake refresh
I've searched but haven't found an answer:
Will the ABS light, once it's on, stay on until a car is driven after a complete brake service (hoses, calipers)? The reservoir was completely drained, refilled, and pressure bled (LF, RF, LR, RR).
I removed all the wheel sensors to see if they needed cleaning while doing the work and they were fine. Reinstalled them.
ABS light is on. Still have work to do so can't drive it yet but before I get everything all buttoned up and since it's on jack stands - I need to know if I should go back through the system or if it will go away (assuming everything is fine) after it drives for a bit.
Old Dec 17, 2024 | 11:06 AM
Jon89's Avatar
Read your OBDII codes and report them here....
Old Dec 17, 2024 | 11:11 AM
AbnMike's Avatar
With my reader the OBDII codes are proprietary.
Nothing has changed on the car - it has not been driven since new calipers, lines, and a fluid flush.
Old Dec 17, 2024 | 11:46 AM
RichardS's Avatar
I can't remember whether the ABS light stays on on my XK8 until the car gets up to 5 mph or something. Some of my vehicles do that and some don't.
Richard
Old Dec 17, 2024 | 12:08 PM
Y2KJag's Avatar
You need a better scan tool. You can clear the ABS errors with the scan tool, and then drive and see if it recurs. You'll also be able to post the codes. It may be coincidental.
Old Dec 18, 2024 | 11:21 AM
AbnMike's Avatar
To close this out - yes the ABS light will go off after driving.
Robert Laughton
Oct 4, 2018 03:59 AM
alan924
Apr 24, 2018 12:56 PM
Vee
May 22, 2014 02:36 PM
ropetec007
Mar 8, 2014 02:03 PM
NW1996
Jan 30, 2014 04:22 PM
