ABS Light on now ?
Old Jan 18, 2015 | 04:13 PM
kstevusa's Avatar
Default ABS Light on now ?
2003 XK8. Have read the other ongoing thread regarding ABS/ Stability Control, but nothing is related but the light on. We replaced the rear shocks,required removal of the ABS sensors & unplugged, and 2 other tasks. After the ABS sensors were unplugged, we did the head rest repairs on both seats and then replaced the spark plugs. Head rests required the ignition key to be cycled several times, on-off. Once the Shocks were replaced and the ABS senors cleaned and replaced, we finished the jobs, but the car is still on jack stands and has not moved. We started the car and the ABS light came on as well as Ck. Engine. Pulled the codes for the CK Engine and then erased them. NOTE. No Ck Engine or ABS prior to these jobs. Did not jerk on wires or damage them , so how do we clear the ABS light? No problem with either until we cycled the key w/o the ABS sensors plugged in the harness. How do we clear the ABS Light Please?
Old Jan 18, 2015 | 04:42 PM
cjd777's Avatar
Try the hard reset after charging the battery. Some times you need to have a drive cycle to get a reset, especial on the Check Engine Light.
Wayne
Old Jan 18, 2015 | 06:52 PM
kstevusa's Avatar
Forgot to note new battery and re-charged after the jobs completed. Trying to avoid Hard Reset since re-programing so many functions tends to require so many different operations. Garage Door,Phone and then the car. :-)
Old Jan 18, 2015 | 06:57 PM
RJ237's Avatar
The abs fault was caused by turning the ignition on with the sensors unplugged. Once you start driving again that will clear on it's own unless something is damaged.
Old Jan 18, 2015 | 11:33 PM
beg3yrs's Avatar
That's exactly what I discovered just today. Finished replacing struts, upper strut mounts, upper ball joints and tie rod ends after much cursing and saying other things that would make a sailor blush.
Got it all reassembled, took it out for a short test drive and everything felt and sounded good except for the sight of the ABS light being on. By the end of the ten minute drive, it was off. Whew ...
Old Jan 19, 2015 | 04:08 AM
wolfpck1's Avatar
a jaguar that makes you curse..... say it aint so
Old Jan 19, 2015 | 06:19 AM
kstevusa's Avatar
Thanks Guys!. Was hoping not yo have to re-program all the functions. Since the car has not moved, the sensor could not had a reading, only that they were missing for a time. WHEW!
Old Jan 19, 2015 | 08:48 PM
motorcarman's Avatar
The fault you had was that the rear wheels were turning but the front ones were NOT.
That is a fault according to the ABS module. The difference in wheel speed was MASSIVE and the module flagged that fault.
If you had read the ABS codes you probably would have seen both front wheel speed sensors faulted (no signal).
A test drive corrected the fault and the ABS module was 'happy'. (but the faults are probably still logged as codes in the module)
Many Jaguar modules clear a MIL automatically when the fault is rectified, although the code is still logged in the module if you read it. Some modules require clearing a code with the diagnostic tool (like CATS faults) or the indicator will not shut off.
Some cars like my wife's VW TDI Beetle need the airbag light cleared even if the fault is rectified. The light remains ON until I clear it with my VAGCOM.
bob gauff
Old Jan 27, 2015 | 05:50 PM
kstevusa's Avatar
UPDATE. Brought car home today and the ABS light cleared w/i 1/4 mile. All is well in the world. No codes or messages or noises. :-)
Old Jan 28, 2015 | 04:39 AM
wolfpck1's Avatar
also the abs light may stay on till you get the car moving sometimes after a long sit... mine does this occasionally and clears after i get it above 10 mph .
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
innzane
Sep 2, 2015 10:08 AM
