ABS Module Repairs
Old Nov 29, 2014 | 08:12 PM
walkman1's Avatar
Default ABS Module Repairs
Has anyone used the company MYAIRBAGS to have the module repairs done? Their add on the forum lists an $89 charge for the work. I have read the threads on soldering the circuit board, and it seems simple, but I might be better off leaving it to the specialists.
Old Nov 29, 2014 | 09:07 PM
tberg's Avatar
I used a local company that if I recall correctly advertises on ebay, and I believe it was $45.00. Can't remember the name but it was in Reseda, CA.
Old Nov 30, 2014 | 07:52 AM
aode06's Avatar
AGREED $45-50 bucks on ebay.
Old Dec 2, 2014 | 12:00 PM
walkman1's Avatar
I sent my unit out yesterday to a company in Van Nuys for the $45 fix. Did your ABS light and messages disappear right away after you installed the repaired unit. I have the car in storage status for the winter, so I will not be driving it until next April.
Old Dec 2, 2014 | 01:22 PM
brgjag's Avatar
I have used them twice and several other folks here have also.....
Automotive Scientific Inc. Your #1 Source for ECU, TCU, ABS, EBCM, Climate Control and Speedometer Repairs
Old Dec 2, 2014 | 03:20 PM
walkman1's Avatar
I sent my module to Module Repair Pro.
Old Dec 2, 2014 | 08:38 PM
Spurlee's Avatar
Module Masters
Old Dec 6, 2014 | 06:57 AM
walkman1's Avatar
Default Repaired Module
I am putting my repaired module back in today. However, my Jag has been put away for the winter with no road insurance. Will the ABS lights go out upon start-up, or does it usually take a few miles to see if the fix worked? I can let it run in the driveway for a while if that would suffice to clear the system.
Old Dec 6, 2014 | 07:02 AM
Dennis07's Avatar
The yellow abs icon will probably still be lit no matter what. But if all is well, there will be no message such as "abs/trac not available".
Good luck to you, sir.
Old Dec 6, 2014 | 08:14 AM
aode06's Avatar
drive it around the block, it will go out
Old Dec 6, 2014 | 09:54 AM
Poppyboy's Avatar
After I did the ABS module fix myself (as well as cleaning the speed sensors), the messages and lights immediately went out; a week later, back on; A few days later, back out. They continue to come and go, and it's been a couple of months since the two fixes.
Old Dec 6, 2014 | 02:30 PM
walkman1's Avatar
Smile
The repaired module is back in and the ABS light and warning messages are no longer on. :
trosty
26
Dec 18, 2022 06:40 PM
ericjansen
Dec 19, 2021 12:20 AM
skyryder
Mar 25, 2016 08:18 PM
mrobinson
Sep 18, 2015 07:20 AM
JeffinSwitz
Sep 16, 2015 01:44 PM
