abs reset?
Old Apr 13, 2014 | 03:16 PM
multiplecats's Avatar
Question abs reset?
Hello,
I'm currently chasing a fault code indicating a missing tooth on the front
wheel speed sensor ring. Initially I gave it a good clean and cleaned out the clag between the teeth; however the ABS fault light still turns on after about 10 secs. of driving.
Is the ABS fault light supposed to go out immediately any fault is rectified or does the system have to be reset/cleared first (ie battery disconnect etc)?
Thanks.
Old Apr 13, 2014 | 03:30 PM
jimbov8's Avatar
You have nothing to lose by trying the reset, just have the radio code on hand before you disconnect.
Is the sensor sitting close enough to the wheel and have you checked the wiring to it.
Old Apr 13, 2014 | 08:30 PM
motorcarman's Avatar
Perhaps someone replaced the wheel bearing and used the 'chisel' method of reluctor nut removal/install (damaged/missing tooth?????)
Maybe the sensor link harness is 'open circuit' at times?????
The system (light) should reset but the DTC will still be logged in the module.
bob gauff
Old Apr 14, 2014 | 08:45 AM
Thanks guys.
I've been round and cleaned/checked all the other reluctors/sensors and this particular one doesn't look too different. All the teeth are present and there is a gap of about paper-width between them and the sensor.
I did clean out the connector and some corrosive green powder came out, but I've now washed it out with electronic cleaner fluid. The connector pins looks OK as far as I can see - don't seem to have dissolved!
This is not an intermittent fault, once the ABS warning comes on after 10 seconds it always stays on.
I'm worried that I may have cured one fault and now another has shown up. Unfortunately the C1141 code was from the dealer's reader - mine doesn't show body codes. Maybe I should invest in that AutoEnginuity device :-)
Next I'll probably try the reset - after that I'll check the sensor readings at the ABS module.
Andrew
Old Apr 14, 2014 | 08:54 AM
Dennis07's Avatar
Another pretty common bug that might cause what you're seeing is a broken wire inside the final wiring section that leads to the sensor. (Once the error light comes on, I think it will stay on until you shut the car down and restart.)
Suggestion for a test: restart the car, but before driving off exercise the steering lock-to-lock and let's see if that induces the error message.
Old Aug 17, 2014 | 08:15 AM
times2fxp's Avatar
"steering lock to lock?"
Old Aug 17, 2014 | 08:57 AM
cjd777's Avatar
Time, it moves the wire back and forth on the sensor and a short in the wire will show up before any movement of the car. Helps pinpoint if it is the wire or possibly a connection.
Wayne
Old Aug 17, 2014 | 09:54 AM
marvin.d.miller's Avatar
Talking Lock to lock...
Start the vehicle, and turn the steering wheel all the way to the left, or right, until it hits the "lock", or end of the turning motion. Then, turn the wheel all the way in the other direction until you reach the other "lock".
Also, underneath all those brake lines under the hood on the front driver side, towards the front of the car, there is a black ABS box that is about 6 inches square and about 2 inches thick (on my 99 XK8 and in the U.S.). Inside that black hermetically sealed box(plastic welded shut) are two tiny soldered connection points. Those two tiny connection points are where the connection is that completes the circuit for the ABS. They are highly prone to failing due to improper amounts of solder, and it sounds like yours has completely failed. Not to worry, you can still drive the car.
At this point you have 4 options:
1) Buy a new unit (black ABS box) MUCHO BUCKS!!!
2) Search this site for the instructions on how to fix the tiny soldered connections. It's on here somewhere, I've watched it. Probably a link to a youtube video.
3) Go completly ghetto and put a piece of black electrical tape over the ABS light
4) Live with it.
Old Aug 17, 2014 | 10:20 AM
wolfpck1's Avatar
look online for a abs module repair place. cost here is about $75 us for an exchange or a rebuild of your unit.most places wont exchange or repair if it has been previously opened so look into this as a first option.
Old Aug 17, 2014 | 01:12 PM
Jag#4's Avatar
Here's one link to the DIY fix. There are others, but this one has pictures.
https://www.jaguarforums.com/forum/x...-repair-62539/
I did this repair myself and while I was a little nervous about taking a hacksaw to such an expensive part, all went well.
Have been trouble free (no jinx please!) for almost 2 years.
Msteiner
May 16, 2016 12:19 AM
goges
Oct 5, 2015 04:53 PM
millertic
Sep 30, 2015 08:11 PM
leep123
Sep 30, 2015 03:41 PM
mrplow58
Sep 30, 2015 08:56 AM
