Acceleration Problem... Help requested!
Old Aug 25, 2022 | 09:33 AM
ajmbwas's Avatar
Default Acceleration Problem... Help requested!
Vehicle is 1997 Jaguar XK8 RHD Auto 4.0 Convertible.
Acceleration 'slowly' through to 50-60-70 mph etc presents no problems.
If I accelerate 'quickly' pulling away or overtaking etc then once I get to around 50 mph I get an Amber Warning. With 'Engine Fault'
If I continue to accelerate then I get a RED warning with 'Reduced Performance'
The engine then sounds sluggish with occasional missing....
Once I slow down again then the RED warning goes off and then followed by the Amber and all returns to normal.
It seems to be an acceleration problem....
Engine Temp is normal... Fuel use is normal... Spark Plugs recently changed... Performance Air Filter fitted...
It only occurs when I put my foot down..... What's the likely problem...?
Old Aug 25, 2022 | 10:27 AM
Jon89's Avatar
Have you read the OBDII codes? Best place to start....
Old Aug 25, 2022 | 10:45 PM
srpope80's Avatar
When is the last time you replaced the fuel filter and cleaned the MAF Sensor with CRC MAF Sensor cleaner? Either and definitely both will cause this as well.
Old Aug 26, 2022 | 12:42 AM
Pistnbroke's Avatar
I had the same recently caused by water in one of the plug hoes ...that was caused by a badly fitting coil cover which let in water. I got no codes
If its missing you want to look at causes for that inc leaks in the induction tract.
Old Aug 26, 2022 | 01:41 AM
drmike's Avatar
Is the performance air filter a recent addition? I'm not sure what one of these is
Has it only happened since you changed the plugs? Which plugs did you fit?
The missing is due to the reduced performance thing isn't it? It's not a warning it's a statement that the car is in reduced performance mode capped at 3,000 rpm I think.
Old Aug 26, 2022 | 01:57 AM
Pistnbroke's Avatar
The misfire is causing the reduced performance ..find the cause.
I lived in Australia for 10 years and the Aussies are obsessed with air filters and Snorkles because its so dusty. Tests showed that the standard paper filters were less restrictive and caught finer dust than the others like K&N.
Old Aug 26, 2022 | 06:05 AM
JayJagJay's Avatar
Do you get a CEL with the yellow and red warnings, and if so,,, is it blinking? If it is, stop what you are doing... I don't want to sound all alarmist or like a crazy person BUT disfunctions in the CATs can be a baaaad thing. Just throwing it out there.
Old Aug 27, 2022 | 01:11 PM
ajmbwas's Avatar
Default Acceleration Problem... Help Requested!
Yep! Cleaned out the MAF Sensor and throttle housing etc.
Could not get any MAS Sensor CRC Cleaner but used CarLube Electrical Contact Cleaner which does the same thing.
All seems to be ok now... Good acceleration so far.
Will give some more tries again over the weekend.
Many thanks for the advice.
x350
21
Dec 29, 2020 06:49 PM
Roman the Austrian Swede
Nov 14, 2017 04:07 PM
sg18438
Oct 16, 2016 05:04 PM
Thempsc
Sep 7, 2015 02:29 AM
espy1949
Nov 13, 2012 04:17 PM
