Access to aerial?
Old Nov 30, 2025 | 05:12 AM
Ant Buck's Avatar
Default Access to aerial?
I need to remove the aerial for repair or replacement on my x100 convertible .I have removed the four bolts that hold the frame down, but can't get the frame to move. It still feels attached at the back somehow. I have had a look under the frame and there seems to be a plate running up the back. I need to move this as i have very little access to remove the aerial. any thoughts are much appreciated.
Old Nov 30, 2025 | 02:48 PM
Y2KJag's Avatar
I think you have to remove the amp, SatNav and CD changer in order to access all the bolts required to remove the housing in order to get better access to the aerial. IIRC I replaced mine without removing the amp stack. You'll need a 1/4" extension long enough to reach back there, bur there are only 2 bolts holding the assembly to the mounting flange.
Old Dec 1, 2025 | 11:12 AM
Ant Buck's Avatar
Thank you very much.
Old Dec 1, 2025 | 12:46 PM
Jag_Willi's Avatar
Did you unscrew the nut on the outside of the antenna?
Best regards, Willi
ptjs1
Apr 8, 2024 12:00 PM
Ant Buck
Apr 7, 2023 09:13 AM
JoMa93
Feb 20, 2023 10:53 PM
catroad
Aug 8, 2017 05:10 PM
Reginald Adrian Hankin
E type ( XK-E )
Dec 29, 2016 06:34 PM
