advice: Cleaning interior of soft top
Old Aug 31, 2015 | 04:52 PM
reedmtn's Avatar
Default advice: Cleaning interior of soft top
My 97 Jag has a horribly dirty and somewhat smelly soft comfortable top. I can't use a carpet cleaner because I can't scrub the fabric without tearing at it and causing damage. What has anyone experienced and found to be valuable and fairly simple to clean dirt and stains from the interior of a soft convertible top.
Thanks...Ritzy needs cleaning
Old Aug 31, 2015 | 05:00 PM
WhiteXKR's Avatar
Rubbing alcohol or brake cleaner (yes, brake cleaner) will work. If the stains are reddish brown, and the fabric is limp and droopy though, the foam backing has deteriorated. If this is the case (and it is very common), the reddish stains will return after a while from the foam dust. The only permanent solution is a new convertible headliner. It is not particularly easy to install, so an auto upholstery ship is your best bet.
Old Aug 31, 2015 | 05:06 PM
reedmtn's Avatar
Any thoughts on how much a new liner would cost. I have considered this?
Old Aug 31, 2015 | 05:10 PM
WhiteXKR's Avatar
Aftermarket liners are about $200 on ebay. Labor depends on the individual shop, but will probably be several hundred dollars.
Old Aug 31, 2015 | 06:38 PM
test point's Avatar
Brake cleaner . . . yes . . . brake cleaner . . . .
The cleaning will not last if you have deteriorated foam sitting on the fabric but it sure will for months.
Old Sep 1, 2015 | 08:28 AM
frankc's Avatar
Here you go this is what I did Franks XKR Story. - Page 12 Hope this helps.
Old Sep 1, 2015 | 08:47 AM
reedmtn's Avatar
[QUOTE=frankc;1299504]Here you go this is what I did Franks XKR Story. - Page 12 Hope
Old Sep 1, 2015 | 11:54 AM
worrasf's Avatar
Well I used car upholstery cleaner (foam in a can with a plastic brush attached) - it worked an absolute treat - grime gone and no watermarks
Old Sep 1, 2015 | 02:47 PM
reedmtn's Avatar
I am losing faith in this forum.....really.....brake cleaner? It would stain and destroy the fabric and if it got on any leather or other paint it wouldn't be good. I ended up having it cleaned professionally at Tint world and it looks brand new. But brake cleaner....no....can't buy that one.
Old Sep 1, 2015 | 08:35 PM
Jag#4's Avatar
Originally Posted by reedmtn
I am losing faith in this forum.....really.....brake cleaner? I ended up having it cleaned professionally at Tint world and it looks brand new. But brake cleaner....no....can't buy that one.
Bet they used brake cleaner while you were reading old magazines in the waiting room.
Old Sep 1, 2015 | 09:38 PM
reedmtn's Avatar
It's comments like that and that kind of mentality that ruins a good forum. What a shame and put down to all thegood folks on here.
Old Sep 1, 2015 | 10:13 PM
MediaBobNY's Avatar
The main ingredient in original formula (=chlorinated) brake cleaner is perchloroethylene. Also known as 'Perc', it's the solvent used in dry cleaning fluid.
Makes a bit more sense now, eh?
Old Sep 1, 2015 | 11:56 PM
Stamford's Avatar
reedmtn, unless I'm missing something, I honestly don't see anything offensive in Mike's comment. He was just teasing you. It's actually a funny thought if the "secret formula" of the professionals turned out to be $4 brake cleaner from AutoZone.
Old Sep 2, 2015 | 07:44 AM
Jon89's Avatar
reedmtn,
You would be wise to heed the advice of many long-time members here, even if that advice seems somewhat unconventional at times. The voices of experience can and will save you thousands of dollars during your ownership period of these cars if you will only listen. Keep in mind that anyone giving consistently bad advice will eventually be sniffed out and booted by the forum administrators....
Old Sep 2, 2015 | 12:32 PM
Jag#4's Avatar
Apologize if I offended. It was not intentional. And sorry my poor attempt at humor was not taken that way. I enjoy this forum very much and that is largely due to the respect shown most of the posts.
Again, not meant to offend.
Old Sep 2, 2015 | 06:29 PM
test point's Avatar
Still using brake cleaner . . . .
Old Sep 5, 2015 | 08:04 AM
reb1999's Avatar
I used a cleaning fluid called Afta. I think it is the same cleaner Dry Cleaners use for clothing. Used a little on a non fiber cloth, rub gently. Go too far color fades. Works well on most items EXTEPT plastic. I'd keep it away from the urethane wood as well. Rich
Harry Dredge
Oct 4, 2024 05:37 PM
Rivguy
Dec 4, 2020 07:55 AM
Bret_T
Sep 4, 2015 05:01 PM
robiwhan
Sep 4, 2015 10:43 AM
King Charles
Sep 3, 2015 12:40 AM
