Air Assist Control Valve question
I'm chasing rich codes again. Sigh.
I start the car when cold, and often it shows a very rich mixture, and the STFT is like -25% on both banks. (what really chaps me is that it doesn't happen all the time. This thing is possessed.) Anyway, for research I pulled the hose from the connection at the rear of the TB. I got plenty of manifold vacuum at the hose, and the mixtures immediately went to a positive 25%, indicating a vacuum leak. So far, so good. I plugged the hose with my finger, and the mixture immediately went to -25% again. I repeated this a couple of times. Then I reconnected the hose and it dropped back to around -25%. This does not seem right.
How does that valve work? I don't get a code for it, but I think I should test the operation if possible. Any hints? Also, I searched a lot online and can't find any pix of the valve itself. Denso makes a pile of similar ones for Hondas, but it appears that the Jag part isn't available. Is this a serviceable part, i.e. something that can be removed and cleaned? Or, is it time to bite the bullet and send the TB in for a rebuild?
TIA, and a Merry Christmas to everyone!
Two questions. If the valve was closed, for whatever reason, during cold warmup, would the system read rich?
And, I noticed, by looking at another TB I have, that the electrical part of the valve can be adjusted a bit, and that turning it a few degrees one way or another causes the internal valve to open a bit more or close a bit more. Would adjusting this make any difference in the rich/lean condition?
I have recently checked the fuel pressure and it was normal, IIRC something like 40 or 45 psi, fluctuating very little when revving the engine.
All this assumes the car is in closed loop, which it won't be immediately after a cold start, so make sure any readings you are getting over the live data is in closed loop mode.
I would also expect any obvious fault on the AACV to generate a code.
I think all you can do at this point is experiment - for example make a note of trims and MAF reading at start up, then disconnect the AACV and see what changes at another cold start up.
I'm not sure at this point I would try adjusting the valve as you describe unless you have a guaranteed way to get it back to the original setting - it's never a good idea to introduce a new unknown variable when trying to fault find.
xFyght
Aug 7, 2013 06:18 PM
e21pilot
Sep 4, 2012 07:36 AM
