Air bag light - RESOLVED
Old Oct 30, 2013 | 12:12 PM
Davebc's Avatar
Default Air bag light - RESOLVED
Removed and replaced steering column yesterday, now have air bag light on. Pretty sure everything got connected correctly, any suggestions?
Light blinks a couple times then stays on. I will count the blinks tonight and report back here.
Thanks.
Last edited by GGG; Oct 31, 2013 at 04:00 AM. Reason: Add 'RESOLVED' to thread title
Old Oct 30, 2013 | 03:59 PM
For relevant parts of the SRS (Supplementary Restraint System) in the area where you've been working, check the Instrument Pack harness connectors and the clock spring / Driver's Airbag connector. A poor connection on either of these will trigger the Airbag warning light.
The blink code should give more information.
Old Oct 30, 2013 | 05:46 PM
Davebc's Avatar
Will do.
What's the clock spring please?
Old Oct 30, 2013 | 06:37 PM
Here's the info to decipher the flash code.
File Type: pdf
Old Oct 30, 2013 | 06:39 PM
Originally Posted by Davebc
Will do.
The clock spring transfers the electrical signals from the SRS to the Driver's Airbag module.
It's located on the steering column behind the steering wheel.
Old Oct 30, 2013 | 07:51 PM
Davebc's Avatar
I checked the flash, looks like 19 (once, then nine more) and looking at the flash code bulletin provided by Norri I'm looking at clock spring and connectors as you mentioned Graham.
Old Oct 30, 2013 | 08:54 PM
Davebc's Avatar
Default Problem solved
Just checked under dash and I found I forgot one last grey connection on left side of wheel!
Thanks for all of your help guys.
Old Oct 31, 2013 | 04:02 AM
Dave,
Good news.
I've added RESOLVED to your thread title to help others looking for a solution to this particular Airbag issue in future.
Old Oct 31, 2013 | 06:00 AM
smithtrevor's Avatar
Well Done !! Good news another owner resolved an air bag fault, the forum will soon have a library big enough to resolve them all. TS
Old Oct 31, 2013 | 07:42 AM
Dave - thanks for coming back and adding in the final detail of your fix
Graham has kindly added RESOLVED to the thread title to help others in future too....thanks Graham
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
redrover41
23
Sep 25, 2015 01:33 PM
OkieTim
Sep 2, 2015 12:48 PM
