Air Bags and ASC
Old Mar 19, 2010 | 10:54 AM
xsvjag's Avatar
Default Air Bags and ASC
Just when I thought I had read about all the quirks and strange happenings, I think I am experiencing a new one.
This morning I noticed that the passenger side airbag-disabled light was on as I was driving, but when I came to a stop it went off. Accelerated and it came on again, stop at a light and it goes off. It continued that all the way to work. Thinking it was the weight of my purse rolling over a sensor in the seat at acceleration, I put it on the floorboard after about the third on/off sequence, but it stll continued. Does anyone have insight on what might be causing this?
On another topic, the ASC, trac not available light comes on on a more frequent basis and it appears to me it could be related to temperature. I had this happen last summer and had no issues over winter. Now that the temperature is getting warmer it is happening more often again. Especially after it has been driven, shut off and then driven again. I've read the posts on dirty sensors causing the light to come on. I'm not sure how to clean the sensors but all was well for a few days after I washed the car on Saturday, so I think I may have rinsed the dirt/brake dust off? (Is it possible to do that?)
I have a copy of the JTIS CD but it wasn't really helpful as it shows an arrow pointing to the rotor on the wheel. So I'm wondering if someone can tell me how exactly one goes about cleaning the sensor.
Please and thank you.
Old Mar 19, 2010 | 11:15 AM
H20boy's Avatar
Those sensors in the seat do go out after time and 'use', so that is a possiblity, that or a chaffed wire under the seat. Those are the only things I can think of.
As for your wheel speed sensors, if you use OEM brake pads, the dust can accumulate pretty quickly on the sensors. Mine did just that, then I cleaned and replaced the pads, light never went back on. If you take off your wheel, you will see the sensor just sticking out on the side of the hub, held on by one bolt and a wiring connector. You can disconnect, unbolt, clean off with some dish detergent + water using a tooth brush, dry it off, and replace. (keep the contacts dry, just in case). I'd just do the front wheels first, then take it for a spin.
Keep us in the loop on your progress. That'll teach you to take along all that stuff in your purse.
Old Mar 19, 2010 | 12:24 PM
xsvjag's Avatar
Ah, but it's my anti-carjacking device that contributes the majority of the weight. Scared to go anywhere without that in a convertible that has "jack me" written all over it. Glad I live in Texas where I have the right to protect what's mine.
Thanks for the advice, I'll see if I can get a good look at (and clean) the sensors this weekend.
Old Mar 21, 2010 | 03:13 AM
H20boy's Avatar
Found this in a XK Technical guide regarding the passenger seat. Check those 'incline' levels...
I also 'believe' in the the protection method you speak of.
Old Mar 21, 2010 | 12:10 PM
xsvjag's Avatar
Thanks!
Old Oct 17, 2011 | 04:20 AM
plums's Avatar
Old thread ... but if everyone believed everyone else possessed an anti-carjacking device and was fully prepared to deploy it ... people would be more inclined to act better.
Just sayin'
Now, back to searching for answers to "trac not available" and "no start but cranks".
Old Oct 17, 2011 | 06:35 AM
Reverend Sam's Avatar
In South Africa carjacking is common but firearms are severely restricted. I saw a video which demonstrated a flamethrower device which squirts flaming gasoline out of both sides of the car. It burns the potential carjacker alive, and, surprisingly, is perfectly legal.
Old Oct 17, 2011 | 06:38 AM
Found the video...
http://www.youtube.com/watch?v=fDrzMGdYWZc
Last edited by Reverend Sam; Oct 17, 2011 at 07:07 AM. Reason: Updated link to video
xjrjag
Aug 17, 2019 03:45 AM
pnwrs2000
Jan 15, 2018 07:20 PM
Johnken
Sep 15, 2015 05:46 PM
Chuck Schexnayder
Sep 12, 2015 10:30 AM
