Are all door latches the same?
Old Nov 29, 2017 | 06:37 PM
gillmcc's Avatar
Default Are all door latches the same?
Hi Folks,
I have the dreaded "door ajar microswitch" problem on the 2004 XKR Coupe and rather than swap the switch (and potentially get it wrong) I thought I would swap the entire latch (thanks to Sam's excellent youtube video).
I have seen several different latches for sale on ebay and all have different part numbers but seem to be the same. As the doors never changed I am guessing the latches didn't either?
Can anyone advise if any latch will fit?
Thanks in advance folks!
Old Nov 29, 2017 | 06:45 PM
NBCat's Avatar
The latches are different from left to right and are designated as 'deadlocking' and 'Except deadlocking'. Which do you have?
The latches are also different for RHD and LHD vehicles.
Old Nov 29, 2017 | 06:47 PM
gillmcc's Avatar
Hi NBCat,
I have a RHD with deadlocking and I need the passenger (left) door latch.
It's a UK car so should any passenger door latch work from another UK car?
Old Nov 29, 2017 | 06:50 PM
NBCat's Avatar
Originally Posted by gillmcc
Hi NBCat,
For a RHD vehicle with deadlocking, the LH door latch carries part number GJA1081EK. All RHD deadlocking LH door latches appear to be the same.
I hope this helps!
Old Nov 29, 2017 | 07:00 PM
gillmcc's Avatar
Thanks a million!
I saw GJA1081FJ for sale an was hoping that would fit! I will keep searching! Thanks again!
Old Nov 30, 2017 | 11:04 AM
Barry_Tucker's Avatar
I want to know what the heck does deadlocking and non deadlocking mean ...and how do you tell which one you have ?
Old Dec 1, 2017 | 03:18 AM
When a vehicle is deadlocked (also called double locking), an intruder cannot simply break a glass to reach through and open the door using the interior handle - the interior handle is inoperative. It's an additional level of security.
This is the way it works on European specification vehicles:
If you have double locking fitted, a second press of the remote (within 3 seconds of first press) double-locks all doors and sets the alarm system. Once double-locking is completed one signal will be heard and the direction indicators will give one long flash.
The US security system specification has some differences and this MAY not be the same there.
Old Dec 1, 2017 | 03:26 AM
I have the dreaded "door ajar microswitch" problem on the 2004 XKR Coupe and rather than swap the switch (and potentially get it wrong) I thought I would swap the entire latch (thanks to Sam's excellent youtube video)......
If you can remove/refit a door latch assembly then your skills are certainly sufficient to replace a microswitch.
Note the error in Sam's video in the section on removing the latch link which is a good way to break it. This is the correct way to split the link:
Are all door latches the same?-latch-link-1.jpgAre all door latches the same?-latch-link-2.jpgAre all door latches the same?-latch-link-3.jpg
Old Dec 1, 2017 | 07:12 AM
I am about to remove my drivers door latch in order to replace the door ajar micro switch. I'm not sure that I understand the photos above. Is the procedure to :
Push the black collar downward and then apply sideways pressure to the the steel rod ?
Old Dec 1, 2017 | 07:57 AM
..... Push the black collar downward and then apply sideways pressure to the the steel rod ?
CORRECT
The lower section stays on the door latch. Trying to pop it out of the latch arm as Rev Sam describes in the video is an almost certain way to break it.
