Alternator light stays on but chargning over 14 volts at the battery
Old Jan 21, 2026 | 05:05 PM
Pantera928's Avatar
Default Alternator light stays on but chargning over 14 volts at the battery
2003 XKR. The alternator light on the gauges stays on but checking the voltage at the battery show about 14.2 volts.
Any idea of a cause for this.
THanks
Old Jan 21, 2026 | 05:24 PM
motorcarman's Avatar
When did it start this?
If the ALT was a 'rebuilt', then the regulator was probably NOT a correct DENSO unit but aftermarket.
If it just suddenly appeared, then could be fauty reg assy or faulty wiring/connection?(rodent chewing?)
Other than that, I have NO IDEA.
Old Jan 21, 2026 | 08:14 PM
Pantera928's Avatar
No idea of the history but it was this way a year ago when i first drove it.
No record of any alternator change/repair but that is meaningless.
Old Jan 22, 2026 | 01:55 AM
Pistnbroke's Avatar
Faulty diodes always show up as warning light anomalies including WL ON with ignition OFF. 14 V is not too high so sounds like regulator OK
Old Jan 22, 2026 | 11:26 AM
Pantera928's Avatar
Thanks. I pay pull the alternator and have my local shop check it out. Not high on the priority list but it will get there.
Old Jan 22, 2026 | 08:55 PM
Pantera928's Avatar
This is what i keep seeing. Not sure if this is related but I keep hearing a series of 5 beeps coming from the dash area periodically.
Old Jan 23, 2026 | 02:41 AM
dibbit's Avatar
This seemingly unrelated thread explains how the battery light works - there is a separate output from the alternator which controls the light:-
https://www.jaguarforums.com/forum/x...1/#post2895376
Old Jan 23, 2026 | 09:13 AM
Pantera928's Avatar
Very informative. THanks
Old Jan 30, 2026 | 09:03 AM
markmywords's Avatar
Hi
I had the same thing when I changed alternators, there is a 3 wire version and 2 wire version..
I put a 2 wire on and the light stayed on charged ok, but not really correctly..
So I changed to a 3 wire and all was perfect again..
Check the terminals behind the altenator...
Good luck!
Old Jan 31, 2026 | 06:06 PM
Pantera928's Avatar
Thanks @markmywords This is the first i have heard of this. When the weather gets better, I will take a look.
Old Feb 22, 2026 | 11:53 AM
Pantera928's Avatar
Here is a weird one. THe Battery light that has been on for over a year stopped coming on after I replaced the drivers door module and the latch assembly!!
Any ideas?
Old Feb 23, 2026 | 02:12 AM
Pistnbroke's Avatar
See post 4
Mr rx-7 tt
Feb 27, 2025 01:21 PM
stran0020
Aug 23, 2022 05:33 AM
t.rhodes64
XJ40 ( XJ81 )
Dec 25, 2013 10:59 AM
baffourg
Feb 5, 2013 08:59 PM
harryc
Jul 22, 2011 08:07 AM
