Anti-roll (sway?) bar bushes
Old Mar 6, 2014 | 10:15 AM
MCW739's Avatar
Default Anti-roll (sway?) bar bushes
Should these be fitted dry or with some lubricant?
Old Mar 6, 2014 | 03:08 PM
smithtrevor's Avatar
I have done this job on a Ford Cougar...(i wouldn't have thought a Jag was a lot different), i did not use any grease but the key was to "pinch" the bushes when fitted and then fully tighten to torque with the weight of the car on the ground. The idea being when the bush takes the weight of the car they are free to turn to the working envelope.
For what it's worth that's what i did and i've covered 20,000 miles since. TS
Old Mar 6, 2014 | 03:31 PM
JSC's Avatar
JSC
I have replaced the right bush on my car a few months back. Did a dry fit, and so far it seems OK. If that was not the correct way I can always fix it.
Old Mar 6, 2014 | 08:20 PM
Gus's Avatar
Gus
Dry!
Old Mar 7, 2014 | 12:25 AM
avos's Avatar
Some say that if you use poly bushes (so not stock ones) you need grease them to avoid possible noise. Although I assume you have stock ones, and dry would be fine as already said.
Old Mar 7, 2014 | 03:23 AM
RaceDiagnostics's Avatar
Hmmm.. well I put red grease on mine before fitting, I must have read that this should be done somewhere as I had never heard of red grease before hand.
Old Mar 7, 2014 | 07:34 AM
mike66's Avatar
What does JTIS say? My copy isn't working right now. I seem to remember grease from somewhere, but I'm easily confused these days (according to my wife).
Old Mar 7, 2014 | 07:38 AM
ccfulton's Avatar
I greased mine when I put the poly bushes in.
A sway bar is a torsion spring, so will rotate in the bushing as it's working, so it made logical sense (at least to me) that grease wouldn't hurt.
As to whether it's necessary, the first 4 posts seem to suggest that it is not.
Old Mar 7, 2014 | 01:27 PM
From the workshop manual.
Installation
1.
CAUTION: Make sure the Castrol NTR grease is only applied to the
inner surface of the mounting bush. Failure to follow this instruction may
affect the retention of the bush in the retaining bracket.
• NOTE: Make sure bushes are seated correctly in the stabilizer bar's
retaining bosses and crossbeam recesses.
Fit both mounting bushes to stabilizer bar.
Apply a thin film of Castrol NTR grease to the inner surface of the
bush.
Fit bush so that split is facing towards rear of vehicle.
Repeat procedure to fit opposite-side bush.
Old Mar 9, 2014 | 01:25 PM
Gus's Avatar
Gus
If you are going to us a lubricant and I do not but if you do be sure it is not a non-petroleum non-silicone that is meant for rubber. Using a petroleum based lubricant will cause the bushing to elongate resulting in the same reason you are changing it now!
TreVoRTasmin
Feb 23, 2021 03:13 PM
MrWhite
33
Oct 22, 2015 10:29 AM
JagBrian
Oct 1, 2015 12:52 AM
dpappyp
Sep 29, 2015 01:28 PM
