Any rec's for an iPhone/Ipod Touch Holder (UK)
Old Jan 25, 2014 | 01:13 PM
LondonXK8Boy's Avatar
Default Any rec's for an iPhone/Ipod Touch Holder (UK)
Title says it all
I don't think it'll suit a stuck on the window one you see ..
Old Jan 25, 2014 | 02:24 PM
graham11's Avatar
Default holder
hi mate,have you thought about the vent holder,lots to pick from on ebay,i got one for my satnav and looks a nice neet fit just above the clock as the fitting clip pins fit one in each left and right vent so bang in the center its a very small mount so fits flush with the dash heading when you remove your phone or whatever you need to fit there
Old Jan 25, 2014 | 03:48 PM
Have a look at the Brodit Proclip:
List Jaguar XK8 / XKR 1998 | Brodit
I used these in both my XK8's.
Old Jan 25, 2014 | 04:17 PM
Default Graham
I've looked at the web-site - it looks good - do u need two parts then? The web-site isn't easy to navigate to buy tho' - it doesn't seem to have a check out - when i looked on eBay it didn't specify the XK8.
Old Jan 27, 2014 | 04:23 AM
You would need the clip (available for either dash or console) and the appropriate cradle for your iPhone.
I found several UK suppliers by Googling [Brodit Proclip + Jaguar XK8 + iPhone]
Old Jan 27, 2014 | 06:49 AM
kreyszig's Avatar
the one in the apple store is really good. "Kenu airframe"
Kenu Airframe Portable Car Vent Mount for iPhone - Apple Store (UK)
its £20 but £20 well spent I reckon. Works very well and couldn't be simpler
Old Jan 29, 2014 | 08:20 AM
BurgXK8's Avatar
I use this, but not with the vent mounts:
Bracketron
It comes with a sticky pad that can be put on the wood part of the dash leaving no residue if removed. Here in the US the last thing we want to do is block the AC vents in the summer! Plus, if you try to remove it from the vents, you may take a few parts of the car with you.
Old Jan 29, 2014 | 03:05 PM
smoggyx100's Avatar
Title says it all
I have tried 3 or 4 types and I have settled on a vecro strip mounted under the clock and on the back of the phone.
Least intrusive and easiest to mount and unmount the phone.
Old Jan 29, 2014 | 06:04 PM
aholbro1's Avatar
These offer a lot of versatility:
RAM Mounting Systems, Inc.
By far the most durable of 3 or 4 different mounts I've tried.
I got an X-grip after noticing a colleague runs one on his Harley
Old Feb 15, 2014 | 12:06 AM
abraxus's Avatar
I would second the Brodit mounts. They have one with a pass through connector so you dont have to fiddle about connecting a cable every time, and can just drop the phone in.
I have mine wired behind the dash (so no visible wiring) to a Parrot kit which gives charging and both bluetooth and hard wired dock connection to the stereo.
Finbarr1975
Sep 5, 2025 08:38 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Larry-Cleveland
Feb 9, 2019 03:17 PM
Finbarr1975
Oct 4, 2015 05:32 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
