Any of you guys use this? Ultra gauge
Old May 12, 2015 | 06:15 PM
Stumpy's Avatar
Hello Steve
Sounds like you are coming to terms with it well.
Forgot to give you the hint to force 9141, so long ago since I set mine up.
I have my alarm set for 105°C to err on the safe side. Then if it goes off I can get it out for visual monitoring. As I keep mine in the centre arm rest (tucked the cable out of the way through dash etc), unless I am wanting to monitor or check something.
If I remember correctly I turned off the alarm for pending trouble codes, as it kept alerting for P1111, which is not a fault condition.
Old May 13, 2015 | 09:17 AM
Rey's Avatar
Rey
I have been using a ScanGauge for years. It has the same functions as the UltraGauge, but is a bit easier to mount. I mount mine on top of the steering column cover with velcro. I have an off-on false alarm about an intake vacuum leak. It throws a code. In fact, there is no vacuum leak that I can find. My wife drives the car mostly, and she simply resets the CEL using the ScanGauge.
99xk8guy
May 28, 2024 09:36 PM
abonano
25
Sep 25, 2015 10:43 AM
adamn
Sep 10, 2015 09:23 AM
1100me
Sep 7, 2015 06:26 AM
Bcrary3
Sep 3, 2015 03:48 PM
