Auto Transmission clunk
Old Mar 30, 2018 | 10:13 PM
Jetjock17's Avatar
Default Auto Transmission clunk
I have a 2004 XK8 that shifts smoothly when cold but after several minutes of driving, the initial shift from start to the next gear is accompanied with a jerk and a clunk. The rest of gear changes are smooth. The car has 69,500 miles on the clock. Thinking of changing the tranny oil. Your thoughts?
Old Mar 31, 2018 | 02:21 AM
JagV8's Avatar
1. do it
2. please post in the correct forum - someone may move this thread
Old Mar 31, 2018 | 03:24 AM
I've moved your question from General Tech Help to XK8/XKR forum. This is the place to post technical questions about your model and you will also find many threads on the same topic here.
Old Apr 2, 2018 | 09:03 AM
fmertz's Avatar
If you do not know the history, look into the replacement of the filter/pan as well as the connector sleeve (fairly inexpensive plastic parts to buy). Consider Mercon SP as the fluid. Make sure the shop knows how to do the temperature-based refill procedure (no dipstick here). This trans is widely used (including Ford models), so the expertise is out there. At a later point, you can do a simpler flush/refill to get rid of the rest of the old fluid.
If shifts are still not smooth, consider re-setting the adaptations. This is a drive cycle performed under the supervision of the Jaguar/Land Rover SDD factory software.
Separately, your transmission could be running really old code. That code can be re-flashed using the factory SDD software with the appropriate cabling.
Altogether, this 6HP26 transmission is well known, and there are other services/parts to throw at it for various problems. The bridge seal and the 3 rubber tubes are listed (mostly on BMW applications), but the valve body has to come off (trans stay on the car, so not a huge deal). You can get new solenoid valves, or even a rebuilt valve body but this is more $ obviously. Lots you can do under some form of a budget as the trans does not have to come off the car for every little thing.
Best of luck, keep us posted.
Lawrence
XJ40 ( XJ81 )
Feb 2, 2015 09:36 PM
Lawrence
Oct 4, 2014 02:21 PM
Macedon
Aug 8, 2014 04:06 PM
JWT
Jul 6, 2010 03:57 AM
Frankie
XJ40 ( XJ81 )
Apr 13, 2009 01:31 PM
