Bad Headlight Causing Failed Emissions?
Old May 16, 2014 | 10:58 AM
David's XKR's Avatar
Default Bad Headlight Causing Failed Emissions?
I've got a 2003 XKR coupe with 87k. Tried to get emissions done and they said their computer can't communicate with XKR. Went to another shop, same thing. Took to dealer and they say entire ISO network down. They then traced that to a faulted right front headlamp module and now want to replace the headlamp. Does this make any sense?
Old May 16, 2014 | 12:18 PM
dodgerjames's Avatar
hid headlights have a module which they say you cant but seperately,well i have bought one at £125 (water dam) and it was fixed and i done it myself. hids4u southampton england
Old May 16, 2014 | 12:50 PM
WhiteXKR's Avatar
It is conceivable. The headlamp leveling module is on the same network segment.
Chances are if it is simply unplugged it will allow the emissions test to proceed, but you may want to observe if the headlamp position one of your lamps is likely stuck at is going to be a problem for you.
Old May 16, 2014 | 01:07 PM
So it might be the leveling module that needs to be replaced?
Old May 16, 2014 | 01:11 PM
WhiteXKR's Avatar
Yes, that is the only portion of the headlamp that is connected to an in-car network directly.
Old May 16, 2014 | 01:34 PM
Thanks. Do you happen to know the part number and of a non-Jaguar source for the module?
Old May 16, 2014 | 02:53 PM
JagV8's Avatar
Might perhaps be a wiring fault. Modules should be on ebay / wreckers / etc and not much demand so reasonably priced.
Don't know on your car but on S-Types they need configuring (dealer tool).
dsnyder586
Dec 29, 2024 07:39 PM
Richard_gib
Sep 12, 2015 07:08 PM
avern1
Sep 8, 2015 06:25 PM
jaguarbill
Sep 5, 2015 11:43 AM
Bowman
Sep 3, 2015 03:17 PM
