badge replacement
Old Apr 23, 2017 | 02:23 AM
Rigelprime's Avatar
Default badge replacement
As you can see in the highlighted area, the Jaguar badge has been pried off the silver backing oval which is still attached to the front quarter panel.
I have ordered and received a replacement but it involves also replacing the silver oval which is still attached to the front q panel. Before I crawl under there and try to get behind the liner, does anyone have previous experience messing with these? If so, anything I should pay attention too? Any suggestions? I would like the car to be as beautiful as possible because in short order she will lead our Mayday parade and carry our Queen. No big deal you say? :O We have the oldest and longest running MAyday celebrations in North America - right here on our little island...
Old Apr 23, 2017 | 04:53 AM
Hare's Avatar
You take the wheel off and then the wheel liner comes out. Easy enough to do. You should be able to see everything clearly after that
Old Apr 23, 2017 | 07:32 AM
Rigelprime's Avatar
thanks Hare. Seems simple enough...should be able to do that in the carport
Old Apr 23, 2017 | 09:59 AM
rothwell's Avatar
Those are just held on with adhesive. You should be able to get some fishing line behind an edge and gently work it around to separate it from the fender.
Old Apr 23, 2017 | 11:36 AM
avern1's Avatar
On my 1997 the badge is pressed with 2 clips holding it in place. You tke one of those thin cards from the grocery store club or an old hotel plastic key. Insert it between the chrome on the front side and push to the rear while prying out with a piece of plastic or wood. The tang should release and the badge pop out.
Old Apr 23, 2017 | 01:21 PM
omgimali's Avatar
This should be the same for the badge.
Old Apr 23, 2017 | 01:52 PM
DevonDavid's Avatar
Slight digression but might be of interest ...............
on UK cars, the amber direction indicator is in that position, and the two indicator lamps in the front and rear bumpers (fenders) are just "dumb" amber reflectors. But ........ the wiring is the same for all cars so behind that badge, there's a connector, just as there are two behind my front and rear reflectors.
So - as in the link above - should be possible from outside the car without any major surgery - I can change the bulb in mine without removing wheel and wheelarch-liner.
Old Apr 23, 2017 | 01:58 PM
omgimali's Avatar
That is how I removed the badge in my x308 XJ, there is a signal indicator in the UK cars but in the US cars it is Badges. Why? I don't know.
Old Apr 23, 2017 | 03:34 PM
Rigelprime's Avatar
Your assessment was correct. It was held in place with foam backed adhesive and on the back was a wire pair and connector which had a wire U clip attaching it to the badge oval. Removing it took some small amount of paint in a couple of spots - even though I was very careful and in other areas it left a wicked adhesive that I threw fingernail polish remover at - didn't work but that's ok I didn't like the color of my last pedicure KIDDING!!!) and finally acetone and elbow grease cleaned it up. Now I am just waiting for touch up paint to cure. Will check it in a few hours but it will be an easy install from here.
Old Apr 23, 2017 | 05:03 PM
rothwell's Avatar
Something that I should have mentioned is that you could have just removed the inner leaper from the new badge and glued it into the old badge. Sorry.
Occasionally those leaper inserts will show up on ebay without the badge for a much cheaper price too.
Old Apr 23, 2017 | 06:12 PM
Rigelprime's Avatar
it was too well stuck to remove the leaper but the other bit worked out ok. in fact I had enough time to clean and seal the convertible top as well. Can't wait to see how she looks out in the sun working on her gives me the exercise I need...
