BBS montreal wheel photos without trim ring
Old Jan 13, 2013 | 09:45 AM
benpearson's Avatar
Default BBS montreal wheel photos without trim ring
I have a set of Montreal wheels that I need to refurbish, I am thinking of removing the chrome trim ring and then having the whole wheel powdercoated, leaving the trim off.
I have read posts where people have said that they have done it before, but I would like to see what the wheel looks like without the trim, I don't want any big gaps left behind.
Thanks!!
Old Jan 13, 2013 | 12:12 PM
MarcB's Avatar
Although these are not Montreals, I do have a couple of pics of my Perseus wheels powder coated without trim rings. These may be of some help as the barrel and gap should be similar, if not identical. Personally, and I may be in the minority here, I like the look. The first pic is a bit blurry, sorry about that.
Old Jan 13, 2013 | 12:50 PM
benpearson's Avatar
thats exactly what i was looking for, thanks!!
Your wheels looks great, i think that they look just as good without the trim, and since i will be powder-coating anyway, i don think that you will ever be able to tell its not there.
did you powedercoat them with the two parts of the wheel separate, or while it was all bolted together?
Thanks,
Ben.
Old Jan 13, 2013 | 04:15 PM
MarcB's Avatar
These particular wheels were purchased used "refurbished". Hard to say if the wheels were disassembled prior to finishing but as far as I can tell, from the consistently of the finish and the area around each bolt, it appear these were disassembled prior to powder coating. There is a video in the forum about refitting new trim rings and the technique required to disassemble and reassemble would be the same except for the refitting of the trim ring.
Old Jan 14, 2013 | 03:43 AM
simkins's Avatar
Had my "Montreals" re-furbished and the rim trim removed. The wheels have to be split to re-furbish, so I had the outer rim powder coated in a chrome finish,looks great.
Old Jan 14, 2013 | 05:41 AM
dennisw's Avatar
can we have pictures? please
Old Jan 14, 2013 | 05:44 AM
Frog's Avatar
I don't understand - these appear to have the SS trims on?
Old Jan 14, 2013 | 05:53 AM
Sean B's Avatar
Nope, painted. The centres unbolt, you need an M8 spline bit to remove the 19? Ti bolts, they're threadlocked so heat might be required to move them. Once the centre is out, they can be painted. The tricky one is the valve tube, this will need a new rubber seal on assembly.
Old Jan 14, 2013 | 06:32 AM
simkins's Avatar
Dennis
A numpty like me would never figure out how to up-load photo's
Old Jan 14, 2013 | 07:38 AM
malbec's Avatar
This is what they look like with the rims. I think I prefer them to my Detroits.
Attached Thumbnails BBS montreal wheel photos without trim ring-c01c3341a06d50f8df8fa2d9d54c9d27.jpg
Old Jan 14, 2013 | 07:52 AM
dennisw's Avatar
Dennis
ok..no probs
Old Feb 27, 2013 | 10:30 PM
r0m8470's Avatar
I have mine done w/out the trim ring as well. I've been having cupping issues at the front, and I thought it's due to alignment. I had that corrected but the front tires were done so I bought a pair of replacement.
At the tire shop, when the new ones were about to be balanced, found out that the front wheels were bent. I have them fixed by AWRS (Alloy Wheel Repair Specialist) and they offered me to get the fronts done w/out the trim ring.
First picture is the front (w/o trim ring), the second is the rear (w/ trim ring). It's hard to spot the difference - which is the exact point.
Attached Thumbnails BBS montreal wheel photos without trim ring-bbs-no-trim-ring.jpg   BBS montreal wheel photos without trim ring-bbs-trim-ring.jpg
Old Feb 28, 2013 | 05:45 AM
JgaXkr's Avatar
That wheel looks very familiar to me. The polished aluminum brake hat is the giveaway.
Old Feb 28, 2013 | 06:35 AM
Frog's Avatar
^what are those brake hats and where did you source them?
Old Feb 28, 2013 | 08:35 AM
JaguarXKR's Avatar
Attachment 30101
Attachment 30102
How do you like your Pilot Super Sports tires?
Old Feb 28, 2013 | 11:00 AM
jimbov8's Avatar
+1 Frog
I too would be interested in where to source those brake caps.
They look good and set the wheel off very well.
Old Mar 1, 2013 | 12:11 AM
MarcB's Avatar
The SuperSports are without a doubt the best tires I have ever had. Words cannot even describe the grip, ride quality and quietness.
I recently had the rear pinion seal repaired and my mechanic, who also services Aston Martins and prepares customer cars for vintage racing, mentioned the tires being tremendous. He went romping around on a damp morning and couldn't get them to break grip without a lot of effort.
Now that I have expienced these I will not recommend anything else.
Old Mar 1, 2013 | 12:48 AM
avos's Avatar
+1, These Super Sports have been the best tires on different areas I have had especially traction.
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
Rivguy
Dec 4, 2020 07:55 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
