Best way to disable antenna
Old Aug 19, 2013 | 12:22 PM
krswen's Avatar
Default Best way to disable antenna
I only listen to CD's and would like to disable the antenna so it doesn't rise every time I turn on the radio. 2004 XK8.
Does it have a dedicated fuse? Or do I need to find the wiring connector and unplug it?
Ken
Old Aug 19, 2013 | 12:33 PM
The Coupe's Avatar
I simply unplugged mine, at the base of the antenna.
Open the boot and remove the carpeted side piece on the right side. Use a flashlight and look behind the audio equipment, you'll see the base of the antenna. Simply unplug the wire from the base, and that's it.
Funny enough, even with my antenna unplugged I can still receive radio stations quite clearly, but not for as far a distance.
Old Aug 19, 2013 | 12:49 PM
+1 ^
or leave it parked in the raised position in a supermarket car park. (that will also work).
Old Aug 19, 2013 | 01:01 PM
Richxk8's Avatar
Put in "Disconnecting the power antenna " in the search, plenty of options.
I put a rocker switch inside the console, off for the IPOD & CD changer, on for the radio.
Easy project.
Old Aug 19, 2013 | 01:05 PM
Paul Pavlik's Avatar
Easy project.
https://www.jaguarforums.com/forum/x...antenna-24564/
Old Aug 19, 2013 | 08:47 PM
krswen's Avatar
Pulled the number 9 fuse in the rear box. Perfect solution for my needs. Appreciate the help guys ...
Ken
Old Aug 18, 2014 | 09:16 PM
Jorge526's Avatar
Old thread but very helpful. I disconnected mine this evening and surprisingly I can still get most of my stations here in San Antonio. Once again this forum proved very useful, thanks dudes!
Old Aug 20, 2014 | 07:48 AM
weisberg's Avatar
Default Marine antenna used in trunk option ?
I had mine disconnected 2 years ago but FM stations fade in and out here in Denver, CO and AM radio is unusable. Someone once wrote about running a "marine antenna" around the trunk and connecting it into the system so full reception was restored.
Suggestions on the specific part and where to have it attached?
Old Aug 20, 2014 | 09:46 AM
jonscot's Avatar
i think it was in a reverend sam vid on youtube -
Old Aug 20, 2014 | 09:02 PM
Jag#4's Avatar
Yes, the Rev. Sam comes thru again.
Old Aug 21, 2014 | 02:06 AM
The_Ikon's Avatar
Rev Sam has some really detailed videos! I just spent the last hour and thirty minutes watching his tutorials on a car I don't have! Great stuff!
oldjaglover
Dec 25, 2024 04:33 PM
Presence
Mar 13, 2016 02:21 PM
philwarner
Jan 31, 2016 09:36 AM
Rocky15
Oct 12, 2015 03:42 AM
